Auto Tool Measurement setup,makes gmoccapy slow and difrent configation,
3 years 3 months ago #276015 by Aciera
The line needs to be _removed_.
The point is that having it there in the hal file will try to load gui-pins that are created only _after_ the hal file is executed. Hence the "postgui" entry in the ini file which means "hal file to be executed after the gui is created".
3 years 3 months ago - 3 years 3 months ago #276017 by Kasper-001
then i get this
hm2/hm2_7i92.0: registered
creating ladder-state
Found file(REL): ./custom.hal
CANNOT FIND FILE FOR:custom_postgui
Init tmp dir=/tmp/classicladder_tmp_GPq2hi
INFO CLASSICLADDER---I/O Modbus master closed!
extra emc serial data=8, parity=0, stop=1
INFO CLASSICLADDER---I/O Modbus master (Serial) init ok !
Running HAL shutdown script
ERROR CLASSICLADDER-   Error initializing classicladder user module.
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Note: Using POSIX realtime
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/cnc/linuxcnc_debug.txt
and
    /home/cnc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
cnc@debian:~$
my ini
[HAL]
HALUI = halui
HALFILE = test2.11.hal
HALFILE = custom.hal
HALFILE = custom_postgui hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
Last edit: 3 years 3 months ago by Kasper-001.
3 years 3 months ago #276018 by Aciera
First thing is to remove this line in your ini:
second please post the content of this file:
3 years 3 months ago #276019 by Kasper-001
custom_postgui hal removed from ini
# These files are loaded post GUI, in the order they appear
source custom_postgui.hal
3 years 3 months ago #276020 by Aciera
Looks ok.
So on startup these two hal files will be executed:
And after the gui is running this postgui-hal file will be executed
custom_postgui.hal
Are you getting any errors on startup now?
3 years 3 months ago #276021 by Kasper-001
it startes very slow , and does not look the same
Time to create page: 0.217 seconds
