- Thank you received: 905
NoJo's responded in his original thread I drug up... I suspect he will be able to shed some light on the whole shebang. Might want to pay attention to that one, too.excellent thread guys, I'll look at caxis.comp and see if i can figure it out
Do you think you need to orient the spindle? I gather the C-axis homes every time it's enabled (like my Fanuc), but I don't see the need for spindle orient once a C-axis is available.IE if spindle is enabled, call orient from a macro and then have the output sent to the spindle encoder , when in c axis, the encoder output is sent out to C axis then macro calls home and resets encoder.
As I see it the problem when switching from spindle mode back to rotary mode is to get the motor to match the commanded position of the rotary axis before the encoder was disconnected in the switch to spindle mode. If the commanded position does not match the encoder feedback a joint following error will occur when the encoder is reconnected. That is at least how I understand it.resetting the encoder on C-axis enable results in the C-axis immediately homing.
