[solved] Rehoming Lathespidle / Rotary-Axis from inside GCode
3 years 5 months ago #272105 by spumco
The caxis.com looking always with lathe eyes. What happens if you have a milling machine with toolspindle and A or C axis and want turning? Then we have two spindles and the story begins new. I think first step should be teaching lincnc that round axis only count max. 360° and second step supported rehoming. But i take a look in the homing.c and closed it. Behind my mind...
What do think about this idea? And is there someone who can do it?
The lines get blurry between a mill-turn or a turn-mill, don't they?
I haven't done this, but I believe controlling two spindles can be done in LCNC using spindle.1 for the 2nd spindle motor.  Main spindle would be spindle.0.
So you set up the A-axis with a position-mode PID and a second PID connected to spindle.1.  Switch between them, just like we've been discussing for C-axis lathe stuff in this thread.  Could probably recycle the caxis.comp as 'aaxis_spindle.comp' with some minor editing.
LCNC is already capable of treating a rotary axis as only having 0-359.999 degrees.  See the [AXIS] section of the INI file help document.
Regarding A-axis homing/rehoming:
My mill has an A-axis driven by a servo, open-loop to LCNC.  I'm using the drive's internal home-to-index function through a couple of IO pins:
  • LCNC->Drive
    • start homing
  • Drive->LCNC
    • homing complete
    • alarm
My particular drive doesn't require an 'unhome' signal before homing a second (or more) time. So my "Home-A"​ button (macro) outputs:
  • halui.joint.3.unhome (unhomes A)
  • (slight pause)
  • halui.joint.3.home (LCNC immediately sets DRO to 0.000)
  • start homing (via motion.digital-out)
  • wait for homing complete (via motion.digital-in)
    • if complete w/in time permitted - macro is done
    • if fails to get complete signal
      • alarm
      • unhome joint
All the usual homing data is pre-programmed in the drive (homing speed, index search speed, encoder offset)
The normal LCNC X/Y/Z homing function omits the A-axis entirely; I usually have a trunnion table on the A-axis and I don't always have 360 clearance if there's a long tool in the spindle.  Having a separate HOME-A button helps me remember to check for interference.
Point is, you can home/unhome any joint you want via gcode in a macro.  i.e. the same macro that switches between axis-position mode and spindle-velocity mode can unhome the axis each time its run.  And it's not limited to lathe main spindles.
Unless I misunderstood something, ​​​​​​I think all of your questions/comments are already addressed - or at least manageable - in LCNC.
3 years 5 months ago #272117 by chris@cnc
Thanks for this hint. I see now the option "WRAPPED_ROTARY = 1"
LCNC->Drive
start homing
Drive->LCNC
homing complete
alarm
(slight pause)
alarm
unhome joint
The Same should be possible on a lathe c axis. The "drive-index signal" can touch the halui.joint.3.home and hm2***encoder.reset and then switch axis to closed loop and joint mode.
It doesn't matter which machine or axis we're working on.
It seems I won at my workshop next weekend. Let's see what the big boss say about it...
3 years 5 months ago #272161 by chris@cnc
I test these two points
First thing,  "WRAPPED_ROTARY = 1"
Axis data show 0-360° but joint.pos.fb data is still the same. This is no real option to go to G0 A0 and disconnect encoder for reset.
In case of  connection must be joint.pos.fb an encoder data the same to avoid the following error. And this is serous only by zero possible.
Second idea: try to rehome joint by m-code.
This will not work by M-Code. In terminal works this way one by one.
halcmd setp halui.mode.joint 0
halcmd setp halui.mode.joint 1
halcmd setp halui.joint.5.unhome 1
halcmd setp halui.joint.5.unhome 0
halcmd setp halui.joint.5.home 0
halcmd setp halui.joint.5.home 1
But start this by M-Code, machine is switching to halui.mode.mdi and no manual operation possible.
Now i am on the starting point again. Or did i something wrong?
3 years 5 months ago #272165 by smc.collins
I'm thinking a lot on how to do this, 2 macro's and a hal component to manage the encoder and control switching most likely
3 years 5 months ago #272189 by Aciera
Running a dummy G33 move should cause an index set/reset cycle and zero the encoder counts in LinuxCNC.
I've been playing around with this for a while now, neither G33 nor M19 reset the encoder position when the index signal is detected.
3 years 5 months ago - 3 years 5 months ago #272199 by Aciera
This custom orient component looks like it might do the trick:
forum.linuxcnc.org/10-advanced-configura...sues?start=10#272197
More testing needed.
Last edit: 3 years 5 months ago by Aciera.
Time to create page: 0.093 seconds
