Lathe turret tool changer with absolute encoder
3 years 2 weeks ago - 3 years 2 weeks ago #283029 by Trav328
Thanks for the file , I'm going to look over your tool change loop as that's what I need to do next.
I'm taking a little break form the encoder and just attached my index switch for now , i do want to have the encoder working but its kicking my butt. I can switch between encoder and index setups in about 10 minutes.
Another thing I noticed is it seems to count backwards , if your at t2 and call t3 you wind up at t1 but the bits say t3 , maybe the old controller flipped it in software.
Last edit: 3 years 2 weeks ago by Trav328.
3 years 2 weeks ago #283066 by tommylight
Seems like miss wiring, be it physical wires or in hal.
Do some tests and write down what pin state denotes what tool, then change in hal accordingly. Much easier that dealing with wires.
3 years 2 weeks ago #283071 by andypugh
I did the fix you sent me to but that was for the gray code section and the binary section has some different code.
The same fix is probably applicable in binary mode, if you want to modify carousel.comp.
So when it looks for tool 8 all it sees is 0-7 , and just spins until you close linuxcnc
Or you can fix it in HAL. a 3-way "NOR" function on the other three pins can be used to drive the 4th input pin of carousel.
loadrt logic personality=0x1003 addf logic.0 servo thread net bit1 {bit 1 input here} carousel.0.sense-0 logic.0.in-00 net bit2 {bit 2 input here} carousel.0.sense-1 logic.0.in-01 net bit3 {bit 3 input here} carousel.0.sense-2 logic.0.in-02 net bit4 logic.0.nor => carousel.0.sense-4
The following user(s) said Thank You: Trav328
3 years 2 weeks ago #283115 by Trav328
Thanks Andy , I'm back on shift for a bit but I will dig back into this the next free weekend in the garage , I just left it in index mode for the time being so I can work on the rest.
I checked the wiring a few times and performed a encoder calibration from the factory manual, I did the modification in carousel.comp and reinstalled.
I will give the hal fix a go next.
The next thing to work on is the m6 remap you mentioned in your first reply so it gives the g43 with m6 , I seen mention of an example in the fanucy Sim.
The other thing is sometimes if i call say m6t8 it just switches to t8 in gmoccapy but the tool changer doesent move , sometimes it does , could this be related to having carousel in the prepare loop rather than the change loop ?
If I manually jog the tool changer it always accurately reports the tool number in carousel.0.current-position.
3 years 2 weeks ago #283116 by andypugh
That should be fairly simple, the most basic version just needs to map Tnn to M6 Tnn G43.
It gets a lttle more xomplicated uf you want to add wear limits.
Including position 8?
3 years 2 weeks ago - 3 years 2 weeks ago #283117 by Trav328
Using index mode with my extra prox sensor it reports tool 1-8
Using the encoder it still reports tool 0-7
Time to create page: 0.057 seconds
