Lathe turret tool changer with absolute encoder
3 years 2 weeks ago #283120 by andypugh
Using index mode with my extra prox sensor it reports tool 1-8
Using the encoder it still reports tool 0-7
Which doesn't explain why sometimes M6T8 does nothing. Is that specifically with T8, or was that just an example?
3 years 2 weeks ago #283121 by Trav328
Just an example , when I get home this evening I will run out to the garage and grab a short video that might explain it better than me trying to type it out.
The carousel part itself seems to work well using index , the carousel.0.current-position is always accurate in index mode. I have physical tool fwd/rev buttons and can cycle it through tools no prob.
And when it does work through mdi it works perfect. (Indexing to the correct tool)
It just seems to be something not quite right between gmoccapy and carousel.
3 years 2 weeks ago - 3 years 2 weeks ago #283142 by Trav328
Here is a quick video that demonstrates my issue,  hopefully something simple I missed.
Also some pics of my current tool changer in hal
youtube.com/watch?si=e2___Kt5mBWzWcxB&v=...mNo&feature=youtu.be
Last edit: 3 years 2 weeks ago by Trav328.
3 years 2 weeks ago #283243 by Trav328
i managed to get it selecting all tools last night , the problem was in my tool changer section , this is what wound up working if anyone else has a problem.
net tool-change iocontrol.0.tool-change => carousel.0.enable
net tool-changed iocontrol.0.tool-changed <= carousel.0.ready
net tool-number iocontrol.0.tool-prep-number => carousel.0.pocket-number
net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-preparedm6 remap
next onto the m6 remap and electronic "range" selection, i do plan on continuing to try and get that encoder working and i will update this when i do.
2 years 3 months ago #306466 by Basti189
Hello, sorry to bring up the old thread again, I have read through everything with enthusiasm because I have the same problem with the encoder,
my revolver is almost exactly the same only with 12 places and a brake on the motor .... My question did you solve the problem ? And if so how ?
2 years 1 month ago - 2 years 1 month ago #310540 by Basti
hi, I also had problems with the locking of my tool changer. I have now linked the strob sensor of the encoder to the locking and installed a small safety feature so that if the strob (locking signal) is not there, it goes into motion hold.
Last edit: 2 years 1 month ago by Basti.
