- Thank you received: 2177
Knee mill table height; external offset or something else?
2 years 11 months ago #286633
Replied by Aciera on topic Knee mill table height; external offset or something else?
Ok, so what you need to be aware here is that the change in the axis limit settings will only be used by the planner after a queuebuster. This means that during gcode execution the planner will not automatically use the changed limit values as the lookahead may already have finished queueing the gcode for the planner to be ingested.
Since you seem to want to use this when changing tools you may want to remap M6 to include a queuebuster (eg something like 'M66 E0 L0').
I'm not sure if 'M6' already IS a queuebusting operation so you may want to test your setup without actually putting the tool in the spindle during a tool change.
The following user(s) said Thank You: tommylight, m0602232
- Thank you received: 7491
2 years 11 months ago #286637
Yeah, had a feeling i jumped into the deep end!
Replied by tommylight on topic Knee mill table height; external offset or something else?
We are using custom kinematics here, so things are a little unusual.What am i missing here?
Time to create page: 0.694 seconds
