5 axis kinematics configuration
2 years 10 months ago #287193 by Ahmed.emara
Hello guys
I have 5- axis milling cnc machine ( XYZAB axis ) and can’t find it  in the configuration menu what should i do to setup my machine ?
2 years 10 months ago #287207 by Aciera
If I remember correctly then the configurator will only give you four axes max so you would need to take that and modify hal and ini to 5axes.
Is this for a table or spindle rotary?
2 years 10 months ago - 2 years 10 months ago #287251 by Ahmed.emara
I have a rotary table that contains two rotary axis, in my knowledge it will be called A axis and C axis but when i asked someone he told me it A axis and B axis not C axis.
here is a similar dental cnc milling machine which have the same mechanism and rotary axis
Last edit: 2 years 10 months ago by Ahmed.emara.
2 years 10 months ago #287262 by Aciera
Yes, XYZAB would have been my answer as well.
Have a look at the simconfig in '/axis/vismach/5axis/table-dual-rotary' that has been added to Version 2.9
Time to create page: 0.056 seconds
