If you don't connect the encoder to the drive, the drive won't work. Period.
You can send the encoder signals to the Mesa board (LCNC) one of two ways:
- Drive's encoder outputs
- Can be programmed as unbuffered, direct pass-through to Mesa board
- Or programmed as buffered, but with a 'gear ratio' to keep the encoder signal frequency low
- Encoder "Y" type splitter
- Encoder signals are connected to the splitter, and then to both the drive AND the Mesa board.
- Mesa sells a differential encoder splitter. Very nice, very cheap.
Note that most servo drives are '
basically a huge capacitor bank looking thing all soldered together' inside their nice-looking cases.
Do you have 240VAC single-phase power available for the Ultra 3k? It will work on 120VAC, but your DC bus voltage will be lower and the drive won't be able to spin the motor at full RPM.
My suggestions about using a different motor perhaps should have been more specific. I was suggesting having the motor stick UP from the head (i.e. reversed from existing arrangement). You have plenty of room above the head; a simple mounting plate and some spacers would put the motor pulley at the correct elevation to line up with the existing spindle pulley.
And if you go that route, you could use a VFD and an induction motor... which would be WAY easier than what you're contemplating now. Power the VFD, one cable to the motor, one Modbus to the VFD - done. Add an encoder later once it's running open-loop.
I believe there are a couple YT vids where the authors did exactly that - convert a Syil X4 to VFD and induction motor.
