- Thank you received: 10
Tommy - thank you as usual, especially for the LPT advice.I might be missing something, but from reading this, we have
-a iffy motor
-even iffy-er drive
-eager to buy an iffy-est drive
-for several hundred $ used !!!
That is the point where i would stop, hand brake on and sliding sideways!
The motor has hal sensors, have a look at Granite devices drives, step/dir, analog, and some other stuff, costs under 500$, works as advertised, quite easy to setup, and good customer care if you can get stuff to Finland.
What i do not get it, you can get a new motor and drive for 300$, more power and not iffy, but OK servo system.
Why?
On the parallel port side, using a low count encoder can get quite usable, can do only step/dir, quadrature, PWM, no analog. That low count must be quite low, like 50-100PPM for a 3-5K spindle.
With no feedback to LinuxCNC you can do any speed, as long as it uses one of the above control types.
