- Thank you received: 599
Python Interface Feed Hold
- JT
2 years 5 months ago - 2 years 5 months ago #299622
by JT
Python Interface Feed Hold was created by JT
The python interface feed hold doesn't work for some reason. I can watch the feed hold status change from false to true but the program keeps running in a feed move.
Anyone have a clue what's wrong?
Edit: M53 is on.
JT
Edit: M53 is on.
JT
Last edit: 2 years 5 months ago by JT.
2 years 5 months ago #299627
Replied by andypugh on topic Python Interface Feed Hold
Maybe you need to enable fedd-hold and/or issue a G53?
linuxcnc.org/docs/stable/html/gcode/m-code.html#mcode:m53
- JT
2 years 5 months ago #299629
by JT
Replied by JT on topic Python Interface Feed Hold
M53 is enabled and I can see feed hold toggle from false to true in the status.
The only thing in the python interface is set_feed_hold(int), I don't see any other way to enable is except M53.
JT
JT
2 years 5 months ago #299633
Maybe the Python interface is exactly the same as a G53, in that all it does is enable the feed-hold HAL pin?
- JT
2 years 5 months ago #299634
by JT
Thanks I'll check in a bit.
JT
JT
- JT
2 years 5 months ago - 2 years 5 months ago #299642
by JT
Toggling M53 and toggling the set_feed_hold from the python interface don't change motion.feed-hold. Even setting motion.feed-hold to true doesn't stop feed moves.
Edit: motion.feed-inhibit stops all motion feed and rapid
JT
JT
Time to create page: 0.325 seconds
