Mesa 7i95T PID tuning for velocity mode
- xu
13 Jun 2024 08:31 #302938
by xu
Replied by xu on topic Mesa 7i95T PID tuning for velocity mode
Xiānshēng nǐ hǎo Delta B3L sìfú qūdòngqì méiyǒu màichōng sùdù móshì nǐ shì rúhé shǐyòng sùdù móshì shì yào xiān bǎ màichōng zhuǎnhuàn dào 10v de mónǐ sùdù fāngshì ma? Yīngyǔ shì yòng fānyì ruǎnjiàn fānyì kěnéng bùnéng zhèngquè biǎodá
展开
87 / 5,000
Hello Sir
Delta B3L servo drive does not have pulse speed mode
How do you use the speed mode? Do you need to convert the pulse to 10v analog speed mode first?
The English translation is done using a translation software, so it may not be expressed correctly
展开
87 / 5,000
Hello Sir
- Thank you received: 5336
13 Jun 2024 13:06 #302961
Replied by PCW on topic Mesa 7i95T PID tuning for velocity mode
If the drive has a step/dir position mode, that is what you use
(you don't need a velocity mode even for a spindle)
- xu
13 Jun 2024 20:58 #302983
by xu
Hello sir,
The drive has a step/dir position mode, but it does not mean that the step/dir position mode is prone to vibration during PID adjustment. It will not vibrate when it is in speed mode.
- besriworld
- Thank you received: 92
13 Jun 2024 23:49 #302985
by besriworld
Replied by besriworld on topic Mesa 7i95T PID tuning for velocity mode
You can just play around with the device's pid settings . .. if it is very hard
- xu
14 Jun 2024 21:56 #303028
by xu
Regarding the selection of servo motors, I would like to know if the XINJE DS5L-PTA servo driver is suitable? It supports 5v pulses to directly run the external speed mode, and can set 1000khz to reach the rated frequency without converting analog 10v. Sorry, I can't find the English manual. I can only open the Chinese web page. This is translated by Google, so it may not be expressed correctly.
- Thank you received: 7502
14 Jun 2024 22:18 #303030
Replied by tommylight on topic Mesa 7i95T PID tuning for velocity mode
@ XU
No double posting.
Duplicate post deleted.
Thank you.
No double posting.
Thank you.
Time to create page: 0.412 seconds
