Mesa 7i95T PID tuning for velocity mode
2 years 5 months ago - 2 years 5 months ago #301459 by zmrdko
I'm sorry.
Hardware is
Delta B3-0421-L servos with step/dir control
LJ12A3-4-Z/AY proximity switch (PNP NC 4mm 6-36VDC)
and you can find the hal and ini files in attachment
Full config: github.com/zmrdko/mesa_7i95t_config_PID
Last edit: 2 years 5 months ago by zmrdko.
2 years 5 months ago #301461 by zmrdko
2 years 5 months ago #301481 by PCW
You must use encoder index enable with encoder feedback
 (and use stepgen index enable if you use stepgen feedback)
The following user(s) said Thank You: zmrdko
2 years 5 months ago #301487 by zmrdko
Awesome. It works flawlessly now. And I have what I always wanted. I have to home only once after starting LinuxCNC and now when I push power button, the servos are disabled, but LinuxCNC keeps the position of all the axes. So when I press power again, I don’t have to re-home!!
2 years 4 months ago #302938 by xu
Xiānshēng nǐ hǎo Delta B3L sìfú qūdòngqì méiyǒu màichōng sùdù móshì nǐ shì rúhé shǐyòng sùdù móshì shì yào xiān bǎ màichōng zhuǎnhuàn dào 10v de mónǐ sùdù fāngshì ma? Yīngyǔ shì yòng fānyì ruǎnjiàn fānyì kěnéng bùnéng zhèngquè biǎodá
展开
87 / 5,000
Hello Sir
Delta B3L servo drive does not have pulse speed mode
How do you use the speed mode? Do you need to convert the pulse to 10v analog speed mode first?
The English translation is done using a translation software, so it may not be expressed correctly
2 years 4 months ago #302961 by PCW
If the drive has a step/dir position mode, that is what you use
(you don't need a velocity mode even for a spindle)
