5 Axis GMOCCAPY
- akg1904
- Thank you received: 4
27 May 2024 06:44 #301567
by akg1904
5 Axis GMOCCAPY was created by akg1904
Greetings.
Guys I am thinking of running my 5 axis machine on Gmoccapy-XYZAC, but I have some doubt :
1. Whether the Gmoccapy supports SwitchKins like Axis Display(XYZAC-trrt)
2. Is it as comprehensive as Axis 5-axis.
3. Do I need to make any changes anywhere other than INI file
Regards
Abhishek
Greetings.
Regards
Abhishek
- Thank you received: 7502
27 May 2024 08:23 #301584
Replied by tommylight on topic 5 Axis GMOCCAPY
This is not my forte, but till someone else chimes in:
1 it should
2 it should
3 might need, not sure if there is a 5 axis version of GmoccaPy.
1 it should
2 it should
The following user(s) said Thank You: akg1904
- Thank you received: 2177
27 May 2024 11:22 #301598
Replied by Aciera on topic 5 Axis GMOCCAPY
SwitchKins is independent of the GUI, it uses its own hal pins but you may want to add your own custom panel to indicate the state of the kinematic switch.
There is a gmoccapy XYZAC sim config.
The following user(s) said Thank You: tommylight, akg1904
Time to create page: 0.079 seconds
