Home all axis by Lpt pin
I have a question. How i can Home all(2) axis by one Lpt pin?
Thanx.
Do you want to use one pin as the home switch for all axes, or do you want to use an p-port pin to start the homing sequence?
HALUI = halui
Then in the HAL file adding the line
net home-button parport.0.pin-10-in => halui.home-all
If you want to use a different pin, use a different number. If you find that the sense of the switch is wrong then change it to parport.0.pin-10-in-not. If the button is on the second parport then change it to paport.1.in-10-in.
The "home-button" signal name immediately after the "net" can be changed to suit your whim.
www.linuxcnc.org/docview/html//man/man1/halui.1.html
The "Home All" AFAIK is an Axis thing.
I just solve the problem: It must be the same HOME_SEQUENCE for all axis.
That shouldn't be the case, as it isn't so when doing a "Home All" from the graphical interface.
Halui has a home pin but you have to select the joint to home first.
The docs mention a halui.home-all pin, is that not present in practice?
www.linuxcnc.org/docview/html/man/man1/halui.1.html
