Hello everybody,
I start this post with a bit of a disclamer, i know that nothing beats a straight way and good machine geometry, but in the case of a DIY CNC, not everything can be achieved in the best way.
So, i was having problems machining a sort of flat face on a 400mm x 50mm surface the other day, it was coming out with a 0.7mm (0.027'') bow, and i couldn't for the life of me find where it was coming from, but after a thorough check of the linear rails of my DIY router i found out the same exact bow there.
Bit of context: i've "recently" casted a new epoxy granite base for my router (images can be found on instagram @radial_workshop), and after that i've sent the base to get the surfaces of the x axis and table milled, so to have both straight and parallel X Axis ways and a flat surface to reference everything to.
Having found that bow in the machine i started correcting it by loosening the Y axis rails and tapping them into position, as it was the worst axis in term of bow and out of straightness, and i managed to get within 0.25mm from end to end.
Now i started wandering whether or not LinuxCNC has some sort of compensation for not straight ways, and found ProbeKins.
The wiki for ProbeKins is pretty straight forward (
wiki.linuxcnc.org/cgi-bin/wiki.pl?ProbeKins
). I would probe the table with a fine mesh of probe points and follow the procedure to generate the mesh for ProbeKins.
BUT, being the table flat in relation to the ways, i would need to invert the Z axis correction, is there a way to do so?
