Cannot Addf a custom component. (fails with function not found)
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
10 Jul 2024 16:16 - 10 Jul 2024 16:17 #304846 by rodw
I don't understand this error.
I wrote the attached custom component to decode a MPG I use.
It compiles fine, loadrt works perfectly and the components pins can be seen in halshow at this point
but when I use addf, it raises an error
HAL: ERROR: function 'mypendant' not found
twopass: Error in file ./pendant.hal:
    addf failed
Running HAL shutdown script
It does not matter if I use names= or count= when  using loadrt
Any ideas would be really appreciated. I tried decoding this in hal but gave up as its very messy.
Last edit: 10 Jul 2024 16:17 by rodw.
10 Jul 2024 17:29 #304851 by andypugh
at the command line
halrun
loadrt pendantjog names=mypendant
show funct
will probably answer the question
  • rodw
  • Platinum Member
  • Platinum Member
11 Jul 2024 07:56 #304905 by rodw
Thanks Andy but I am still none the wiser
halcmd: loadrt pendantjog names=mypendant
Note: Using POSIX realtime
halcmd:
halcmd: show funct
Exported Functions:
Owner   CodeAddr  Arg       FP   Users  Name
  • Platinum Member
  • Platinum Member
11 Jul 2024 07:59 #304906 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Cannot Addf a custom component. (fails with function not found)
I did that a few years ago, based on the work here github.com/KurtJacobson/RF45-CNC/tree/ma...HAL%20Components/MPG does make the whole mpg setup easier.
  • rodw
  • Platinum Member
  • Platinum Member
11 Jul 2024 08:01 #304907 by rodw
But if I  do the same thing with say o2, I get an address. What causes i tto be missing?
debian@debian:~/linuxcnc/configs/my_plasma/components$ halrun
halcmd: loadrt or2
halcmd: show funct
Exported Functions:
 00004  7fd5e7818189  7fd5e69e0120  NO       0   or2.0
halcmd:
  • rodw
  • Platinum Member
  • Platinum Member
11 Jul 2024 08:08 #304910 by rodw
Well that was interesting. cornholio, your link showed me I was missing this line
github.com/KurtJacobson/RF45-CNC/blob/ma...nts/MPG/mpg.comp#L14
Fixed now thanks!
  • Platinum Member
  • Platinum Member
11 Jul 2024 08:12 #304911 by Cant do this anymore bye all
I just compiled an dloaded your comp and was just going to compare kurt's to yours. You beat me to it.
All the best, makes hal alot more manageable.
  • rodw
  • Platinum Member
  • Platinum Member
11 Jul 2024 08:19 #304912 by rodw
Yeh, dunno how I missed that,
The MPG is fine as I did it in Hal 7-8 years ago for this same device but I wanted to enable the Plus and Minus jog buttons that also have a third button to select between low speed and high speed jogging. That was very difficult to do in hal.
Time to create page: 0.148 seconds
