Homing with Absolute Encoders (Again)
02 Aug 2024 05:51 - 02 Aug 2024 06:01 #306717 by Sandro
Hello everyone
I am having issues setting up my homing sequence for absolute encoders on my Ethercat servo dirves. I have read trough a few topics here on the forum but did not find the solution to my problem.
Background: I have Lichuan Ethercat servo drives with 23bit absolute encoders. From testing I have found out, that the encoder tracks 512 turns (-256 to +256) which combined with my 5 mm pitch ballscrews gives me a effective range of -1280 to +1280 mm. I need a distance of 0 to 1000 mm on my machine. On startup of LCNC, my encoder reports the correct absolute position of my axis. I have setup the homing sequence as follows:
HOME_ABSOULTE_ENCODER = 2
HOME                    = 0
HOME_OFFSET                = 0
HOME_SEQUENCE            = 0
HOME_SEARCH_VEL            = 0
HOME_LATCH_VEL            = 0
HOME_IGNORE_LIMITS        = YES
#HOME_USE_INDEX          = NO
To the issue: Let's say on startup I am at some random position e.g. 833 mm. LCNC now requires me to press the home button before I am able to switch to teleop mode or issue MDI commands. What happens now, is that the position of the axis is set to 0 and my two soft limits of 0 mm and 1000 mm are applied. This however is in my opinion not correct since the soft limits are now actually at 833 mm and 1833mm. This would lead to a crash if I were to move the axis. I need the homing sequence to keep the 833 mm absolute position value and apply the soft limits at the effective 0 mm and 1000 mm. Basically I need it to just set the "homed" flag and be done with it.
Hope I was able to describe issue somewhat clearly. Any ideas?
Thank you and greetings
Last edit: 02 Aug 2024 06:01 by Sandro.
02 Aug 2024 06:31 - 02 Aug 2024 09:51 #306722 by Aciera
Replied by Aciera on topic Homing with Absolute Encoders (Again)
Maybe immediate homing works for you, see section 6.14:
linuxcnc.org/docs/html/config/ini-homing.html#_immediate_homing
[edit]
Actually I think the above will still zero your position so not what you are looking for. Your solution is likely a custom homing procedure.
linuxcnc.org/docs/devel/html/man/man9/homecomp.9.html
[edit]
All nonsense see below.
Last edit: 02 Aug 2024 09:51 by Aciera.
The following user(s) said Thank You: Sandro
02 Aug 2024 09:14 - 02 Aug 2024 09:34 #306740 by Sandro
Replied by Sandro on topic Homing with Absolute Encoders (Again)
Thank you Aciera!
I just changed the settings to these random values:
HOME_OFFSET = 0
HOME = 0
HOME_SEARCH_VEL = 30
HOME_LATCH_VEL = -5
HOME_FINAL_VEL = 10
HOME_USE_INDEX = YES
HOME_SEQUENCE = 0
HOME_ABSOLUTE_ENCODER = 2
Now it works as intended and my absolute position persists through the homing process (not set to zero anymore). But no idea why...
[edit]
Alright I have found it. It was a simple spelling mistake in the HOME_ABSOLUTE_ENCODER = 2 line. This led to the setting not beeing applied. Nothing to do with the other lines. In fact I can delete anything about homing besides the absolute encoder setting = 2. Feel really stupid now :D
Last edit: 02 Aug 2024 09:34 by Sandro.
02 Aug 2024 09:45 - 02 Aug 2024 16:26 #306744 by Aciera
Oh my, totally missed that one. Thanks for reporting back.
Actually, I think this may be all you need:
HOME_SEQUENCE        = 0
Last edit: 02 Aug 2024 16:26 by Aciera. Reason: Fix the typo
02 Aug 2024 10:28 #306750 by Sandro
Yes correct these are the only lines I have kept. I have set HOME_SEQUENCE = -1 for now so I am forced to home at startup in order to get the soft limits active. This way I will not move the axes by accident without limits in place. Later I plan to automate it so I don't need to press the button anymore.
02 Aug 2024 16:12 - 02 Aug 2024 16:13 #306809 by pippin88
Replied by pippin88 on topic Homing with Absolute Encoders (Again)
For anyone copying and pasting - typo in absolute
Should be
HOME_SEQUENCE = 0
Last edit: 02 Aug 2024 16:13 by pippin88.
The following user(s) said Thank You: Aciera, Darium, Willemsjos
18 Dec 2024 16:04 #316954 by TMonteiro
Replied by TMonteiro on topic Homing with Absolute Encoders (Again)
Hello Sandro,
would like to talk to you about your configuration of the Lichuan Servos with absolute encoder with linuxcnc.
I need feedback coz i am about to pull the trigger on some kits like that.
Thank you in advance,
Tiago Monteiro from Portugal
Time to create page: 0.269 seconds
