- Configuring LinuxCNC
- Advanced Configuration
- How to Spindle Orientation using forward-reverse PWM signal using parallel port?
- fery15sty
- Thank you received: 12
04 Aug 2024 22:08 #306957
by fery15sty
How to Spindle Orientation using forward-reverse PWM signal using parallel port? was created by fery15sty
Can anyone help me, How to Spindle Orientation using forward-reverse PWM signals using parallel port?
I have connected the encoder signal to the spindle axis. and the encoder works fine, I can run rigid tapping. But I am confused about how to configure the spindle orientation to position the BT30 lock before toolchange..
- jpg
- Thank you received: 13
07 Aug 2024 03:54 - 07 Aug 2024 04:09 #307161
by jpg
Replied by jpg on topic How to Spindle Orientation using forward-reverse PWM signal using parallel port?
Bonjour voici une configuration valide pour un tour , les spécifications pour Orient se trouvent dans "spindle hal " ( il n'y a pas le carrousel)
le lien pour comprendre est ici:
forum.linuxcnc.org/10-advanced-configura...indle-activation-m19
Last edit: 07 Aug 2024 04:09 by jpg.
The following user(s) said Thank You: fery15sty, Aciera
- fery15sty
07 Aug 2024 23:06 #307241
by fery15sty
Replied by fery15sty on topic How to Spindle Orientation using forward-reverse PWM signal using parallel port?
how many ppr encoder do you use?
- jpg
08 Aug 2024 02:26 - 08 Aug 2024 02:26 #307246
by jpg
Bonjour c'est un omron e6b2-cwz6c aliexpress , résolution 200 pr
Last edit: 08 Aug 2024 02:26 by jpg.
Time to create page: 0.256 seconds
