5 Axis configuration on linuxcnc
31 Aug 2024 19:01 - 31 Aug 2024 19:02 #309108 by Mr_rookie
5 Axis configuration on linuxcnc was created by Mr_rookie
Hi Guys, thanks for you time.
I've been doing my own search, but without much look to find some tutorial that explain me how to configure files, I know that something may have to be change on hal and ini but after that no much idea. If you guys could explain me what file have to be re-writted or changed with some explanation would be appreciated .
details:
sim axis vismach 5axis.table-rotary-tilting
using vasmich "would like to design my own machine is that is posible"
7c80  "hm2_rpspi"
connection /dev/spidev0.0
linuxcnc 2.9.3
raspberry pi 4
uname -a
Linux pi 6.6.44-rt39 #1 SMP PREEMPT_RT Mon Aug 12 21:10:13 AEST 2024 aarch64 GNU/Linux
let me know if you need more details
thanks!!
Last edit: 31 Aug 2024 19:02 by Mr_rookie.
01 Sep 2024 14:50 #309153 by JackRay
Replied by JackRay on topic 5 Axis configuration on linuxcnc
Hello, nice work.
I'm installing a 5 axis XYZBC machine driven by a berak out with a parallel port --> I want to switch to an ethernet port and raspberry pi 4. I want to add position sensor feedback at least on the B&C axes.
I'm trying to install linuxcnc 2.9.3 on my raspberry Pi 4 under raspbian. Impossible to compile/install the RT patch . see that you have a version “Linux pi 6.6.44-rt39 #1 SMP PREEMPT_RT Mon Aug 12 21:10:13 AEST 2024 aarch64 GNU/Linux” .
Can you help me with this installation?
Thanks for your help
01 Sep 2024 22:48 #309172 by Mr_rookie
Replied by Mr_rookie on topic 5 Axis configuration on linuxcnc
what board are you going to use ?
are you going to use mesa ? o what ??
02 Sep 2024 17:40 #309220 by JackRay
Hello ,
yes, I want to use Mesa cards in the future.
08 Sep 2024 16:44 #309677 by Mr_rookie
you can install linuxcnc 2.9.3 and you may need to activate some option to make the /dev/sdev0.0 to get active also may have slow graphic interface if you are using virtual remote as I do. but that is something easy to fix.
I'm talking about 7c80 board, if you are looking to use a different board you may need different settings.
The following user(s) said Thank You: JackRay
Time to create page: 0.189 seconds
