Custom DH Parameters Kinematics
- Abdulkareem
09 Sep 2024 04:57 #309722
by Abdulkareem
Custom DH Parameters Kinematics was created by Abdulkareem
hello guys,
i am want to implement 5 axis milling cnc machine kinematics with my own DH parameters, i have XYZAB joints , 3 linear and 2 rotational, is genserkins suitable for my machine config or is there is another kinematics model for this kind of config.
- Thank you received: 2177
09 Sep 2024 05:01 #309723
Replied by Aciera on topic Custom DH Parameters Kinematics
'genserkins' does not support linear axes.
- meister
- Thank you received: 502
09 Sep 2024 05:24 #309724
by meister
Replied by meister on topic Custom DH Parameters Kinematics
- Abdulkareem
09 Sep 2024 05:35 #309725
by Abdulkareem
Replied by Abdulkareem on topic Custom DH Parameters Kinematics
do you propose another model that supports dh parameter?
- Abdulkareem
09 Sep 2024 05:36 #309726
by Abdulkareem
i checked this doc, i want to use dh parameter rather than using mathematical equations for simplicity
- meister
09 Sep 2024 05:48 #309728
by meister
unfortunately, i don't know any other kinematics for this, but i should also start working on this topic, maybe it can be extended by the parameters
09 Sep 2024 07:31 #309740
I'm not aware of any other kinematic that would work out of the box.
This is from a comment in 'genserkins.c':
So for your purpose you would need to implement these two TODO points.
Note that 'genserkins' uses 'modified' DH parameters as also pointed out in the comments in 'genserkins.c'
The parameters for the manipulator are defined by hal pins.
Currently the type of the joints is hardcoded to ANGULAR, although
the kins support both ANGULAR and LINEAR axes.
TODO:
* make number of joints a loadtime parameter
* add HAL pins for all settable parameters, including joint type: ANGULAR / LINEAR
