Some issues of using "Home All"(home all joints) when using Multi-ring Absolute
11 Sep 2024 04:51 - 13 Sep 2024 21:12 #309887 by shaying526
At present, I have built a xyz-ac machine tool and used RTCP function, which can work in both simulation and real lathe. I referred to the official 'xyzbc-trt-kins (switchkins)' example
Last edit: 13 Sep 2024 21:12 by shaying526.
12 Sep 2024 06:57 #309995 by andypugh
The only difference is that HOME_ABSOLUTE_ENCODER = 1 means that the joint moves to HOME at the end of the homing sequence, whereas HOME_ABSOLUTE_ENCODER = 2 doesn't move at all,
You might have to experiment to see which works best with your kinmetics / switchkins system. But both should work.
13 Sep 2024 01:52 #310052 by shaying526
Thank you andypugh!
I conducted tests on the machine
I added this line to the ini file
HOME_ABSOLUTE_ENCODER=2
press "home all"
Set the value of the absolute encoder at mechanical zero position to the G54 coordinate system
g10 l2 p0 x-208.621 y-133.6 z-300.0 a-87.85 c-85.18
Use G54 coordinate system
Non RTCP is correct and achieved my goal, but RTCP seems to be incorrect. It seems to use the zero value of the absolute encoder as the kinematic coordinate origin. Below are screenshots of these two situations
Now, I have some new issues
Is this a conventional method for using absolute encoders?
Before this, I thought we still needed to set the zero position of machine.
Now, I use the zero position of the absolute encoder as the zero position of the machine, even though this may be an unattainable position, it is not the coordinate origin of kinematics
13 Sep 2024 03:10 #310054 by Aciera
The kinematics provides inputs to set the coordinates of your table rotary assembly.
This is from 'xyzac-trt.txt':
Hal Input pins:
xyzac-trt-kins.x-rot-point
xyzac-trt-kins.y-rot-point
xyzac-trt-kins.z-rot-point
X, Y and Z rot-point pins represent the
offsets of the center of rotation of the C axis
relative to the machine absolute zero
Add this to the [HAL] section of your ini file and enter your offset values as described above:
# not currently supported by xyzac-trt-gui:
HALCMD = setp xyzac-trt-kins.x-rot-point  <your-value-here>
HALCMD = setp xyzac-trt-kins.y-rot-point  <your-value-here>
HALCMD = setp xyzac-trt-kins.z-rot-point  <your-value-here>
13 Sep 2024 04:27 #310056 by shaying526
Thank you Aciera!
It works! now the xyz axis is correct in RTCP
But it doesn't seem to know that my A C axis value(a=-87.85 c=-85.18) are the absolute zero positions of the rotation axis
When I am at a-87.85 c-85.18, it does not consider me to be at the origin, but rather to have turned to a-87.85 c-85.18
I have looked at 'xyzac-trt.txt'. It seems that it does not have this parameter, the absolute zero setting of the A C axis, such as setting x/y/z-rot-point
What should I do next? Thank you for your reply
13 Sep 2024 06:03 #310060 by Aciera
It's been a very long time since I have used absolute encoder homing but maybe try setting 'HOME_OFFSET' in the 'JOINT_n' section for A and C in your ini file.
13 Sep 2024 21:06 #310110 by shaying526
Thank you Aciera!
Based on your method, I feel like I have completely solved this problem. Now, The machine is running correctly both Non RTCP and RTCP.
As a beginner, I did not understand the correlation between absolute encoders and HOME_OFFSET before this
Thanks again
Time to create page: 0.175 seconds
