ethercat gantry
- Moutomation
- Thank you received: 11
14 Sep 2024 02:08 #310118
by Moutomation
ethercat gantry was created by Moutomation
hello,
I use gantry axis with gmoccapy.
The motors are absolute motors, there is no home sensor in the machine.
There are 2 servo motors on the y axis, this axis is approximately 7 meters long.
For example, at first startup, y1 motor position = 3.000mm
y2 engine position = 5,000 mm.
How can I send the y2 engine to the 3,000 position? What I want to do is to send the y2 engine to the y1 position and then make it work as a gantry when the y1 and y2 positions are equal.
Currently when you first run it for example position y1 is 2,000 and position y2 is 5,000.
When I send the y axis to position 100, y1 position is 100,000 and y2 position is 103,000. How can I make this work without any location difference between them?
- Moutomation
14 Sep 2024 02:18 #310119
by Moutomation
Replied by Moutomation on topic ethercat gantry
I observed wrongly, currently the y2 motor is moving itself to the y1 position, but it is fast, I will check how to reduce its speed.
- Moutomation
14 Sep 2024 02:21 #310120
by Moutomation
Currently, the y2 motor is going to the y1 position very fast. I should reduce this speed, how can I do this?
2.y jog button only moves y1 motor, how can I make it move both motors?
- Thank you received: 2177
14 Sep 2024 02:23 #310121
Replied by Aciera on topic ethercat gantry
Please post your ini file.
- Moutomation
14 Sep 2024 02:30 #310122
by Moutomation
14 Sep 2024 02:52 - 14 Sep 2024 03:59 #310124
Homing for tandem axes is setup using negative numbers for the 'HOME_SEQUENCE' in the [JOINT_n] section of the ini file:
linuxcnc.org/docs/stable/html/config/ini...l#sec:homing-section
Alignment is then achieved using the 'HOME_OFFSET' value in the [JOINT_n] section.
It has been a long time since I used absolute encoder homing but I would suggest to add a 'HOME_SEQUENCE' to all of your joints as described in the link above and then compensate for the position difference using the 'HOME_OFFSET' value for one or both of the tandem joints.
Last edit: 14 Sep 2024 03:59 by Aciera.
- Moutomation
14 Sep 2024 02:57 #310125
by Moutomation
thanks your answer,
Actually, the y2 motor is currently going to the y1 motor position, but it is going very fast, can this speed be adjusted?
- Moutomation
14 Sep 2024 03:06 #310126
by Moutomation
Since it is too fast, if the positon difference is high, the servo driver goes into error.
14 Sep 2024 03:12 #310127
It's not clear to me what method you use to move the y2 motor to the y1 position.
- Moutomation
14 Sep 2024 03:15 #310128
by Moutomation
gmoccapy sets it itself, I did not use any method. For example, when I enter the mdi page, if the positions of y1 and y2 are not equal, the y2 motor moves.
Time to create page: 0.268 seconds
