Spindle servo step/dir Problems
2 years 1 week ago - 2 years 1 week ago #313117 by Stran_ge
Hello People,i have a 3,7kw Servo from szgh that i would like to use as my Spindle Servo via step/dir(external pulse control).
To be more precise i am using a original Mesa 7i95 and the SZGH Servo is SZGH09-2-24-3,7/5,5-4-1500 with a max speed of 15000 rpm.
I can send  the manual for the spindle servo if s1 feels very motivated to read that.
I am a novice with linuxcnc but i watched a video from talla83 and suprisingly got the spindle to turn. I am able to adjust speeds/direction with the according commands.
There is some stuff that does not work.
First vmc_2.halof all using M3 turns the spindle ccw and m4 turns it cw. It should be the other way around. I checked the wiring first and everything seems to be correct as seen in the table for the encoder.
SZGH-ServoMesa 7i950A
0A+ QA3
0A- /QA3
0B+ QB3
0B- /QB3
0Z+ IDX3
0Z- /IDX3
I also checked if the step/dir was correct and it is(polarity too).
If i run the spindle via mdi M3 s200 i get this in halshow (attached picture M3 S200 with positive rps)
If i run the spindle via mdi M4 S200 i get this in halshow (attached picture M4S200 with negative rps)
What i also noticed in Halshow is that whenever i command the rpm to go over 300 the spindle at speed signal does not go true anymore.
I really hope someone can help me here or give me some tipps, i have checked and tried many things but nothing really helped.
Best regards
Nils
File Name: vmc_2.ini
File Size:6.89 KB
File Name: vmc_2.hal
File Size:11.32 KB
Last edit: 2 years 1 week ago by Stran_ge.
2 years 1 week ago #313125 by PCW
Replied by PCW on topic Spindle servo step/dir Problems
Sounds like either the encoder scale or the step/dir scale (or both) are wrong.
2 years 1 week ago #313128 by Stran_ge
Hello PCW,
thank you for the fast answer.
I checked the parameter of the servo with the manufacturer and he told me that the motor resolution per revolution is 1024 which is then *4 4096.
4096/60 = 68.26667 = pulse per second.
How does a wrong scale invert the direction for m3/m4?
2 years 1 week ago #313139 by tommylight
It does not, uless a - sign is in front of it.
So, add a - to scale
Or
Invert the direction pin in hal.
2 years 1 week ago #313141 by Stran_ge
i edit the line:
setp hm2_7i95.0.encoder.05.scale - [SPINDLE_0]ENCODER_SCALE
with a minus but that alone does not change the direction of m3/m4.
If i now go ahead and change a direction parameter on my servo drive to reverse
the spindle turns cw via m3 and ccw via m4 while spindle-fb-rps and spindle-speed-rps signal are both positive at least tho still slightly different values.
So i guess i can hack my way around the m3/m4 problem but still the problem with the speed is not solved by this.
at a certain speed close to 1000 rpm and above the spindle-at-speed never becomes true.
2 years 1 week ago #313145 by PCW
You need to reverse the sign of the step scale (or invert the direction output)
to reverse the spindle
Time to create page: 0.061 seconds
