EMC_JOG_CONT cannot be executed unitl the machine is out of E-stop and turned on
- PostavCNC
- Topic Author
1 year 10 months ago - 1 year 10 months ago #315958
by PostavCNC
EMC_JOG_CONT cannot be executed unitl the machine is out of E-stop and turned on was created by PostavCNC
Hi, there, I made a new configuration of my new machine. Nothing special: open-loop motors, ball-screws on Zaxis and Xaxis, dual helical rack and pining gear on Yaxis. I have used my previous HAL and INI that used to work fine with some modifications on a different machine but with similar hw. But the new machine is showing an error after couple of minutes after operating the machines.
command (EMC_JOG_CONT) cannot be executed until the machine is out of E-stop and turned on
I am running EMC2 on RPI5 4GB. I have attached my HAL and INI for better debugging. Does anyone know what could be the problem? I have never experienced this kind of error. Thank you very much in advance for your kind advices.
Last edit: 1 year 10 months ago by PostavCNC.
1 year 10 months ago #315992
Replied by tommylight on topic EMC_JOG_CONT cannot be executed unitl the machine is out of E-stop and turned on
Most probably from interference on the inputs, caused by spindle or drives motors, subsequent to using unshielded cables or no grounding.
First check if the power supplies and machine is grounded.
Time to create page: 0.043 seconds
