Potentiometer only effective at mm/min (lathe)
  • WKS-3D
  • WKS-3D's Avatar Topic Author
  • Premium Member
  • Premium Member
05 Dec 2024 02:27 #316003 by WKS-3D
Hello community,
I have another problem to solve, namely my feed potentiometer only works at mm/min.
It has no function at mm/rev. The potentiometer for rapid traverse always works.
Is there no other way or can it be influenced?
If you have to run in a program, a potentiometer like this is very helpful ;)
Thanks and best regards
Olli
  • WKS-3D
  • Premium Member
  • Premium Member
06 Dec 2024 12:27 #316124 by WKS-3D
Does nobody really use Probe Basic Lathe?
It doesn't matter whether it's mm/rev or inch/rev, the same effect should occur with both if it's normal that you can't use a potentiometer.
06 Dec 2024 13:47 #316129 by tommylight
Replied by tommylight on topic Potentiometer only effective at mm/min (lathe)
Some do, but not much so far, and not active here much.
Me neither, yet, but probably should need some editing in hal as mm/m and mm/rev are not the same thing nor the same pin in hal.
As to what exactly, i have no clue.
