help to compensate for changes in the rack
1 year 9 months ago #319154 by Thayloreing
I'm having problems with my houter, the rack I used doesn't have very good cymetry, in some points it measures smaller than it should and in other places it gets bigger, things 2 mm apart, mark all the points where this happens, I wanted to know if Is there any way to change the scale in real time of the machine, or something similar, like when it is in a coordinate where, let's say, the average is getting larger, you can compensate this downwards, to reach the exact measurements at which it should be, no. I wish I had to buy a rack new, would there be any way to compensate for these points on the rack?
1 year 9 months ago #319185 by Cant do this anymore bye all
Could mapping of the rack be possible as some do for ballscrews\leadscrews ?
Unfortunately I’m not really up on the implementation.
1 year 9 months ago #319277 by User_paulvdh_42
A few days ago I read in the manual this should be possible, You once do some measurements and create a table, and then you enter that table in LinuxCNC's setup. "lead screw compensation" (ball screw, or rack & pinion, or whatever is all the same for the software) is apparently a special case, you do not need customized kinematics because it's built into each axis.
I'm planning on experimenting with this. My idea is to add a glass scale temporarily along each of the ball spindles, and have a microcontroller measure the position at set intervals. Partly to check accuracy of cheap chinese spindles, and if LinuxCNC can add some correction, that's even better.
But I do wonder about your big deviantions. 2mm is a lot. I suspect your machine has mechanical issues.
1 year 9 months ago #319286 by Thayloreing
Could you point me in some direction? or some topic that did this, I searched but didn't find anything
1 year 9 months ago #319288 by Thayloreing
I've thought of everything, I haven't found any problem other than the rack, the engines aren't, I measured the entire structure with a dial indicator, nothing seat, I've recalculated the scales several times, everything is fine, the only idea is that the rack It came with a different space, as it is unique
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAAngNWGAAABDUlEQVR4AYXRgUZDYRjH4TegFTKgpEqiFJgoWAoMEQGBgBboChaaAKxLKAhAhQqAdAmpBIQolkCFqp2nITvNKXuA7+/Hhzey5OWjE4Nq3rzY1f9/NGHPB549492+8Ww060iCS2XdctZdI3GsECmb+HJoIX6x6EgDm+lURTH+YB7V9nAqE5WNme4YKuOiY6iMe6PaQxUUIuTbswgFVNJwA8sO3Bn6yR6bWZMSNtJwDtuWfHpQxaPx9C9zadil7jrCigbq6UXceNIVKTWUIqypm2ytJdTiNyNeXclF6GttOVfeDEc7qzjR23r3OMFqZKng1kw0mXGLrfibHTScOZWgGv9TdC6ROFeMTgwYiIxvJzMRWQbeGZUAAAAASUVORK5CYII=[/img]
Time to create page: 0.058 seconds
