HAL and INI files for Dual Y Axis, HY VFD
03 Feb 2025 07:37 #320498 by rubinstu
I am migrating to a dual Y axis setup (from a single) and need some help. My setup is basically:
  • LinuxCNC 2.9
  • Parallel port BOB
  • 4x stepper drivers (currently, I have two drivers connected to the same Y step+dir signals, but will move these to each of the Y signals are separate)
  • Proximity sensors for homing (but not for limit checking on each extreme)
  • HY VFD connected via RS-485
Can anyone please share their HAL and INI files with me for their similar setup?
Thanks!
03 Feb 2025 10:50 #320511 by tommylight
Replied by tommylight on topic HAL and INI files for Dual Y Axis, HY VFD
This is for PlasmaC so has a lot of other stuff you might not need, but the homing stuff is with shared switches to save on inputs.
03 Feb 2025 21:11 #320554 by rubinstu
Replied by rubinstu on topic HAL and INI files for Dual Y Axis, HY VFD
Thanks, Tommy! I took a quick look and I think the configs make sense for what I have. I'll give it a shot.
03 Feb 2025 22:32 #320566 by rubinstu
Tommy, thanks again. Using your HAL and INI file I was able see what changes I needed to make and it's working great! Dual-Y axis with "self squaring" homing!
04 Feb 2025 03:55 #320588 by tommylight
You are welcomed, always.
Time to create page: 0.080 seconds
