Tangential Cutter C/A - Following Error/Tuning
14 Feb 2025 15:54 #321597 by notJamesLee
Hi Friends,
The goal is a tangential knife setup with a pizza type cutter blade. To achieve this i have a servo driving a pulley that drives an output shaft with the  blade on it. my goal right now is to get it to jog without errors.
In Axis, when i jog the A axis its slow and jittery. I increased the speed to about 500 deg/min and it moves faster but just as jittery. Anything over 600 i get a following error, I also get random following errors throughout normal jogging. I checked all the connections and they seem fine. Which leaves makes me think it might be the servo tuning.
I tried to follow this guide to tune it (gnipsel.com/linuxcnc-old/tuning/servo.html) however, i cannot find the signal in hal scope. The tutorial calls out 'axis.x.f-error' i can only find 'joint.x.f-error' and get no change when i trigger it with a movement. what is the difference between these two and am I on the right track?
Any advice is greatly appreciated.
14 Feb 2025 16:23 #321601 by tommylight
The following user(s) said Thank You: notJamesLee
15 Feb 2025 14:23 #321659 by notJamesLee
Replied by notJamesLee on topic Tangential Cutter C/A - Following Error/Tuning
Thank you ill dive into this now, not sure how I hadn't found this before. Cheers.
16 Feb 2025 14:55 #321768 by notJamesLee
I seem to have different pins than listed in the tutorial you linked. I've attached a screenshot below of the pins that i have available to  me. This was sort of the same issue i was having with the guide i found and was trying to follow. any idea where i can find these pins and start turning??
16 Feb 2025 15:24 #321773 by PCW
How is the servo drive driven?
Is there feedback to LinuxCNC from the drive?
Can you post your current hal/ini files?
17 Feb 2025 11:06 #321847 by notJamesLee
I hope that i am understanding what your asking correctly. The motor is driven by a CL driver from stepper online. I have the motor wired to the stepgen 3 on the board  7i96 and the encoder to the encoder area on the board. Data sheet attached.
my assumption is that there is feed back from the encoder i just can't seem to find our what channels to listen to so i can tune it in.
20 Feb 2025 19:34 #322149 by notJamesLee
Hi Friends,
Sorry i probably elaborate enough. My goal is to reduce the error in my C/A axis. Currently it jogs, but its shaky and based on what i've seen tuning the servo could help this.
I am reasonably confident in my step and encoder scale figures - 90 deg turn looks like a 90 deg turn. The main issue i am having is that i can't for the life of me find any of the encoder pins that i should be using to tune in HalScope. I know that the tutorial is for a different board but i imagine they would have similar names? i am using 7i96s, below is a screen shot of halwatch when i search for the work "analog". Most of the highlighted ones seem to be inputs, e.g. when i put them in the scope i can enter a value for them. the only ones that seemed to be outputs are in the photo and do no change when i jog the C axis
any advice is greatly appreciated
Time to create page: 0.149 seconds
