CoreXY for plasma table.
16 Feb 2025 07:19 #321736 by Boogie
CoreXY for plasma table. was created by Boogie
Gents,
anyone considered core xy kinematics for plasma table? I can see it working perfectly in my 3D printer. Wondering if CoreXY kinematics is no problem in LinuxCNC. Two cheap servos, 20 or 25 mm wide HTD 3M belts well tensioned and Mesa control can keep moving mass pretty low and give decent accelerations for cutting thin sheets.
What ya think about it?
16 Feb 2025 08:51 #321743 by tommylight
Replied by tommylight on topic CoreXY for plasma table.
For something small it should be OK, but for anything bigger the belts would have to be way to long and to droopy and vibrate like crazy.
Personally, i have built over 20 Plasma and over 10 of 3D printers (mostly Voron 2.4), i would not even bother with it.
The following user(s) said Thank You: Boogie
16 Feb 2025 14:04 - 16 Feb 2025 14:05 #321764 by Boogie
Replied by Boogie on topic CoreXY for plasma table.
You've just killed my initial excitement, Tommy:)
Still wondering if 1500x1000mm work area is too big for HTD3M 20mm wide belts driving ultra light assembly. My concern was more on control side:) I'm not familiar with compiling custom kinematics.
Last edit: 16 Feb 2025 14:05 by Boogie.
16 Feb 2025 17:36 #321783 by tommylight
That would be around 5 meters of belt for each motor, so 20mm belt might be still OK
If you feel like it, go for it for sure.
And to further give you hope, a friend i taught about building CNC's did build a router with 2x1 meter envelope, using 10mm GT2 belts and it works nicely once he got a hang of feeds and speeds, been in use for over a year, and yes it is CoreXY driven by Marlin and LightBurn... Yeah, don't ask
Somewhere in my process of teaching him, he went a bit sideways! :)
17 Feb 2025 03:28 #321816 by Aciera
Replied by Aciera on topic CoreXY for plasma table.
There already is a corexy kinematics installed called 'corexykins'
As an alternative there also is a corexy hal component that lets you use trivkins:
forum.linuxcnc.org/10-advanced-configura...kins?start=10#203954
17 Feb 2025 09:04 #321840 by Boogie
corexy by HAL component?!?! Wow:)
Time to create page: 0.378 seconds
