Monitoring that a relay has contacted
- jayyhu
23 Feb 2025 15:02 #322398
by jayyhu
Monitoring that a relay has contacted was created by jayyhu
Hello,
I have an output signal to a relay, and an input signal from the other side of that relay (to confirm that the relay had contacted or not). Is there a way in HAL (besides writing my own comp) to monitor the input signal and make sure it matches the output signal within a timeframe, and otherwise signal an error if the signals don't match?
Thanks in advance!
Thanks in advance!
- Thank you received: 7502
23 Feb 2025 16:01 #322411
Replied by tommylight on topic Monitoring that a relay has contacted
What is exactly the aim of this?
You can do pretty much anything in hal that is also possible with a comp, so it is your choice.
Monitoring things on screen can be done easily by using VCP
linuxcnc.org/docs/html/gui/pyvcp.html
And use timedelay
linuxcnc.org/docs/2.9/html/man/man9/timedelay.9.html
Then connect that to feed hold or drive enable or e-stop in hal
And use timedelay
- jayyhu
23 Feb 2025 23:28 - 23 Feb 2025 23:30 #322446
by jayyhu
Replied by jayyhu on topic Monitoring that a relay has contacted
For a safety mechanism; the output signal controls 3 relays (which controls the spindle motor & misc circuits), and the input signal is basically all of those relays wired together, so if any of them stops working, I want everything to stop and error out. Thanks for the tip about timedelay--I ended up using a combination of xor2 and ton comps to get the effect I wanted:
setp ton.0.pt 1.0
net ref => xor2.0.in0
net mon => xor2.0.in1
net xor2.0.out => ton.0.in
net err <= ton.0.q
Last edit: 23 Feb 2025 23:30 by jayyhu.
23 Feb 2025 23:35 #322449
Then you might want to use the joint.0.amp-fault input pin as that would disable everything when triggered, but does not e-stop.
The following user(s) said Thank You: jayyhu
- jayyhu
24 Feb 2025 00:27 #322458
by jayyhu
I already have those set to the individual drive error/fault output pins, so I ended up adding a names_misc_errors, which according to the docs, does the same thing.
- Thank you received: 4154
24 Feb 2025 00:36 #322460
Replied by rodw on topic Monitoring that a relay has contacted
Using a safety relay with the estop external to Linuxcnc would be a better solutio.
If you used force guided relays as part of the estop circuit, you should not have an error. These relays have a pin that is forced into the contacts to force them apart. But you should have redundancy so two relays (probably in series) are used and both must be triggered.
- jayyhu
27 Feb 2025 19:28 #322835
by jayyhu
Thanks for the tip about safety relays--never knew they were a thing. I'm converting an existing mill (Emco concept mill 55) that uses a three-relay combo (K1/K2/K3). And the PLC file for the mill has a check to ensure that when the relays are commanded "on" that their outputs are "on" and vice-versa, so I'm just trying to add in that extra level of safety to LinuxCNC as well.
Time to create page: 0.094 seconds
