Spindle orientation
- Sternfox
- Thank you received: 7
02 Mar 2025 07:57 #323015
by Sternfox
Spindle orientation was created by Sternfox
Hi gang, So as the title suggests I'm wanting to know the best way to orient my spindle. My spindle motor is controlled by step/dir (its a giant ac servo)it has DI and OUT for spindle orient start, spindle orient complete as well as encoder out. how would this best be implemented into linuxcnc? I'm trying to use the least amount of io as I can (I'm running out) Thanks
04 Mar 2025 10:13 #323154
Replied by andypugh on topic Spindle orientation
Does orienting the spindle motor work to orient the spindle? (If it's not an exact 1:1 drive ratio then it won't)
What does the motor orient to? Is there a programmable alignment offset?
You say you are running out of IO. Is this because you are using a parallel port?
- Sternfox
04 Mar 2025 10:42 - 04 Mar 2025 10:48 #323159
by Sternfox
Replied by Sternfox on topic Spindle orientation
i have nothing working as yet, the ratio is 1:1
this is what i have tried.
# Spindle Orient Command from LinuxCNC to the driver
net spindle-orient motion.spindle-orient => hm2_7i95.0.ssr.00.out-05
# Spindle Orient Complete feedback from the spindle driver
net spindle-orient-done hm2_7i95.0.inmux.00.input-06 => motion.spindle-orient.is-oriented
just to clarify my spindle driver has inputs and outputs for orient start and orient completed
Last edit: 04 Mar 2025 10:48 by Sternfox. Reason: added more info
- COFHAL
- Thank you received: 62
04 Mar 2025 11:08 #323160
by COFHAL
Replied by COFHAL on topic Spindle orientation
Please try this configuration to orient with servo step/dir, it works for me.
- Sternfox
05 Mar 2025 07:52 #323266
by Sternfox
Thanks for the reply, I managed to get it to work with just two hal commands, my spindle and driver have inputs and outputs for doing this without using the encoder through linuxcnc.
Time to create page: 0.096 seconds
