Adding Pre and Post Gcode to Versa Probe
- Sbvr4
11 Mar 2025 19:58 #323720
by Sbvr4
Adding Pre and Post Gcode to Versa Probe was created by Sbvr4
I have a touch probe that requires an additional activation signal prior to probing. I've mapped motion.digital-out-00 to the pin and would like to know the best way to add M64 P0 before probing and M65 P0 after. Should that be added to each probe routine, or would it be better to use a macro for that functionality? I'm using Qtdragon_hd and Versaprobe.
Thank you
Thank you
- Thank you received: 2181
11 Mar 2025 21:44 #323722
Replied by cmorley on topic Adding Pre and Post Gcode to Versa Probe
What version of linuxcnc?
- Sbvr4
12 Mar 2025 12:39 #323767
by Sbvr4
Replied by Sbvr4 on topic Adding Pre and Post Gcode to Versa Probe
This is for v2.10. My apologies for the ambiguity.
Thank you
Thank you
15 Mar 2025 21:08 #324036
So there is currently no built in way to do this.
The probe routines in master are burried in probe_subprobe.py
github.com/LinuxCNC/linuxcnc/blob/master...ets/probe_subprog.py
The is a pre and post function in there.
prechecks()
postreset()
You could hand edit them to add your calls.
I guess adding an INI pre and post command might be helpful.
What does your calls do?
prechecks()
postreset()
Time to create page: 0.073 seconds
