halui.spindle.0.override.direct-value
1 year 7 months ago #324101 by jazial
Hello,
it looks like halui.spindle.0.override.direct-value is broken
I've tested feed override, max velocity an rapid override and it works correctly; it is only broken on SSO
method :
set override.direct-value to 1
set scale to 0.1
set counts to 5
works nicely except for spindle override
I'm using 2.9.4
1 year 7 months ago #324177 by Aciera
Seems to me that you are mixing two ways of setting overrides, ie direct-value / counts.
1 year 7 months ago #324193 by cmorley
I confirm and see the problem. I'll try to push the fix soon.
*halui_data->so_counts = 0;
should be:
*halui_data->so_counts[spindle] = 0;
The following user(s) said Thank You: tommylight, jazial
1 year 7 months ago #324400 by jazial
To Aciera
It's not very well documented, but you have to set the counts value when you use direct value
It takes me some time to figure it out as I made my tests with spindle speed override and it's not working ;-)
Time to create page: 0.283 seconds
