Getting iocontrol.0.tool-prep-pocket to work
- tsaG
- Thank you received: 4
19 Mar 2025 17:50 #324328
by tsaG
Getting iocontrol.0.tool-prep-pocket to work was created by tsaG
I am currently implementing a rack tool changer. My problem is that the Hal Pin "iocontrol.0.tool-prep-pocket" is always Zero. Do I need to activate it in my HAL File? Its currently initialized as following:
My Tool Table looks as follows:
However, even when inserting Tool1 prep-pocket is always 0. Is there something I am missing?
net tool-prep-pocket iocontrol.0.tool-prep-pocketMy Tool Table looks as follows:
T1 P1 D+36.000000 Z+7.170534 ; tornado
T2 P2 D+6.000000 Z+22.944468 ; 2F 6*15*50 END Mill Carbide
T4 P3 Z+7.119867 ; 2F 3*12*39 VHM wood (sorotec)
T7 P4 D+4.000000 Z+21.747800 ; 1F 4*15*45 End Mill CARBIDE
T9 P5 D+7.000000 Z+22.959800 ; 3F 4*60 fase
T10 P6 D+4.000000 Z+20.327467 ; 3F 4*90° Fase
T13 P7 D+6.000000 Z+37.369466 ; 2F 6*21*50 VHM wood (sorotec)
T17 P8 Z+24.565134 ; graierer 0.2
T15 P9 D+6.000000 Z+27.896133 ; 2F 6*6*18*50 BBHowever, even when inserting Tool1 prep-pocket is always 0. Is there something I am missing?
- matasbuk
- Thank you received: 3
20 Mar 2025 04:34 - 20 Mar 2025 04:35 #324349
by matasbuk
Replied by matasbuk on topic Getting iocontrol.0.tool-prep-pocket to work
You can use tool numbers instead, pocket numbers have to be the same as tool numbers for non random toolchangers
Last edit: 20 Mar 2025 04:35 by matasbuk.
- tsaG
20 Mar 2025 04:48 #324350
by tsaG
Replied by tsaG on topic Getting iocontrol.0.tool-prep-pocket to work
Hm, the issue is that I only have a 12 slot tool rack. I machine wood and metal and have my tool library imported into fusion as well. This means I will be switching tools in and out the tool rack as I need, so it would be great to use the assigned pocket numbers.
Nevertheless for someone not needing to change the tools frequently (or is more flexible in tool numbering) that is a good idea!
- tsaG
20 Mar 2025 16:49 #324382
by tsaG
Sorry for the double post. I already found several examples of carousel and tool changers that circumvent this HAL (Probe Basic also seems to use its own implementation in the var file). Is it save to assume that this function just doesnt work?
If so, I will just follow the PB implementation and add/modify the pockets in my var file and (try) to use these.
Time to create page: 0.836 seconds
