Hello,
I'm working on a mill which make Z+ move to free the tool in spindle.
I need to go to Z++ to disengage locking, but i have to keep under Z25 when machining.
I set up a mux2 component with 2 Z limit values
I normal operation Z limit is 25 and while toolchange Z limit is 180
If i run m6 txx, it works fine, but if I load a program, the plot complain about Z limit, because M6 subroutine mention off limit Z move
If I launch program, linuxcnc complains about Z limit too, but program runs nicely as my limit is moved when it have to
Anyone have an idea to fix this ?
I've tried to add a conditional state before the Z move, but linuxcnc still see the move while plotting
