New Computer - Error Launching
- Thank you received: 7502
02 Apr 2025 12:21 #325531
- tylernyberg
02 Apr 2025 15:21 #325538
by tylernyberg
Replied by tylernyberg on topic New Computer - Error Launching
Thanks. I checked the physical wiring and the MESA I/O config. The Limit switches were not patched correctly in I/O config. Was able to successfully home everything.
I just need to adjust the z settings because the spindle isn't going low enough to the table.
- Thank you received: 4154
02 Apr 2025 16:07 #325547
Replied by rodw on topic New Computer - Error Launching
HOME_SEQUENCE = -1
on both your Y joints is needed. Refer to homing configuration in the docs.
Sometimes you need to invert the sign of the LATCH_VELOCITY to make it go the right way.
Time to create page: 0.860 seconds
