Moving robot joints by only 1 Gcode command?
- heaven
- Thank you received: 3
02 Apr 2025 11:19 #325527
by heaven
Moving robot joints by only 1 Gcode command? was created by heaven
Right now, i'm trying to control a 6-dof robot by linuxcnc, I found kinematic-switch function for moving joints from Gcode.I guess I need to make 3 Gcode commands to just do one task like:
1st-cmd: Use M code command to switch to nontrivial kin
2nd-cmd: use G code command to move joint
3rd-cmd: Use Mcode command to switch back to trivial kin
Yes, it can do my job but it complicated and not friendly. has anyone tried to merge these commands to a single one or any other way to do something similar
- Thank you received: 2177
02 Apr 2025 12:15 #325530
Replied by Aciera on topic Moving robot joints by only 1 Gcode command?
choose an unassigned gcode number and use a remap to fold those 3 commands into one.
The following user(s) said Thank You: heaven
- heaven
02 Apr 2025 22:50 #325572
by heaven
Replied by heaven on topic Moving robot joints by only 1 Gcode command?
Thanks for your reply.
Can you explain in more detail, as I understand I should:
1. Creating an O-code for a subroutine that contains these 3 commands
2. Remap a new G-code that will call the O-code above
Is this what you mean or is there a more straightforward way?
03 Apr 2025 04:16 #325597
Yes, that is the idea.
Here is an example using an ngc remap:
REMAP = G01.1 modalgroup=1 argspec=xyzabc ngc=g011remap
o<g011remap>sub
M66 L0 E0 ;force sync, stop read ahead
M428
o100 if [EXISTS [#<X>]]
o100 else
#<X> = #<_x>
o100 endif
o101 if [EXISTS [#<Y>]]
o101 else
#<Y> = #<_y>
o101 endif
o102 if [EXISTS [#<Z>]]
o102 else
#<Z> = #<_z>
o102 endif
o103 if [EXISTS [#<A>]]
o103 else
#<A> = #<_a>
o103 endif
o104 if [EXISTS [#<B>]]
o104 else
#<B> = #<_b>
o104 endif
o105 if [EXISTS [#<C>]]
o105 else
#<C> = #<_c>
o105 endif
G1 X#<X> Y#<Y> Z#<Z> A#<A> B#<B> C#<C>
M429
o<g011remap>endsub
m2
- heaven
03 Apr 2025 11:53 #325630
by heaven
After trying this idea, i faced another problem: every time I stop the program during movejoint command. The controller doesn't return default kin, I have to use M code to switch back manually, I tried to hack into the controller(the command.c file) to force it to return to default kinematic every time I hit stop or estop. tks, it worked
03 Apr 2025 12:05 #325631
maybe try ON_ABORT_COMMAND:
forum.linuxcnc.org/24-hal-components/280...de-and-e-stop#325497
- heaven
04 Apr 2025 10:26 #325689
by heaven
I tried your way but no luck. Every time I put M428 into on_abort Subroutine, i got error:
interp_error: File ended with no percent sign (%) or program end (M2)
04 Apr 2025 12:10 - 04 Apr 2025 12:11 #325696
Try this in your on_abort subroutine instead of 'M428':
#<kinstype> = 0
#<SWITCHKINS_PIN> = 3 ; set N as required: motion.analog-out-0N
M68 E#<SWITCHKINS_PIN> Q#<kinstype> ; set kinstype value
Last edit: 04 Apr 2025 12:11 by Aciera.
- heaven
04 Apr 2025 22:05 #325736
by heaven
thanks, It's work perfectly now
Time to create page: 0.090 seconds
