I have been testing OrangeCats manual tool change routine and ran into issues I didn't understand - primarily this:
"Linear move on line 128 would exceed joint 2's positive limit"
This error popped up after a new tool was inserted and the height probing complete. But not in a consistent way, and that puzzled me.
I therefore modified the subroutine by inserting some (print, ..) statements. See the attached file.
I then did this:
1) Start LinuxCnc from the terminal, so I can watch the output from the print statements
2) Home the machine (now at (0,0,0))
3) From MDI run: M600 and then M0 T6 (I leave the tool in)
The first probing sequence is executed and the spindle returns to its original position (0,0,0). The print output is:
First tool change
G38.2 Z[-128.000000 - -10.000000] F[400.000000]
Trip point _ToolZRef = -24.113033
4) I load the .ngc file with the cnc project I want to run
5) Manually move the spindle to the workpiece and touch off all axes. The print output is:
First tool change
Trip point _ToolZRef = -32.790000
First tool change
First tool change
First tool change
Trip point _ToolZRef = -32.124133
6) Press Run to start the program. Linuxcnc prompts me to change to the first tool. Since the correct tool is in the spindle, I leave it in.
The probing sequence starts. The print output is:
ToolDiamMM = 4.000000
Old tool length = ######
New tool length = -23.671500
G53 G1 F[500.000000] Z[0.000000 - -24.113033 + -23.671500]
USRMOT: ERROR: invalid command
The problem is clearly that the last G53 command wants to move the spindle above Z0 (valid range is -130 to 0).
Even though it is the same tool in both probing sequences, the small difference (actually rather large??) between two readings may result in the addition of a positive number. This combined with the fact that variable #5183 apparently always is zero (also if I move the z-axis down after homing and before step 3 above).
My two questions:
1) Why is #5183 always zero?
2) Why is the tool-change.ngc subroutine executed when the touch-off button is pressed? (The "First tool change" output is seen multiple times and "_ToolZRef = -32.790000" is printed
at each touch-off button press, even though the z-axis doesn't move. Don't understand where this value comes from?
What am I missing here?
