Is there a bug in the carousel component or am I doing it wrong ATC Denford
1 year 6 months ago - 1 year 5 months ago #327420 by Aciera
Looking at these sections in 'carousel.comp' makes met think that the reverse action does not work in 'counts' mode :
if (rev_pulse > 0){ motor_fwd = 0; motor_rev = 1; motor_vel = rev_dc; timer = rev_pulse; state = 3; [snip] case 3: // timed reverse pulse timer -= fperiod; if (timer > 0) return;
Note that there is nothing changing 'counts_target'.
Last edit: 1 year 5 months ago by Aciera.
1 year 6 months ago - 1 year 6 months ago #327421 by Aciera
I once helped a user who needed to get a ATC turret working that used a stepper and needed to lock the tool by rotating backwards against a pawl (which I _think_ is what yours does):
To get this working we modified a component called 'toolchanger'. The final version is attached here:
forum.linuxcnc.org/38-general-linuxcnc-q...lved?start=80#188377
Last edit: 1 year 6 months ago by Aciera.
The following user(s) said Thank You: Adam Maszynotwór
1 year 5 months ago - 1 year 5 months ago #327590 by andypugh
I don't think that counts mode _can_ work with a Boxford style of toolchanger as the number of steps lost when the motor stalls against the endstop is unknown.
It could be modified to work, but it might be easier to start from scratch as a single-sensor position-mode stepgen changer wasn't really considered when the component was written.
You could even consider doing all the control in the G-code subroutine:
1) Scale the stepgen so that a position shift of 1 is one pocket.
2) Connect motion.analog-in-00 to the stepgen.2.position-fb
3) Connect motion.analog-out-01 to the stepgen.2.posiiton-cmd
4) Connect the home sensor to motion.digital-in-02
(Actually, you can use any numberered analog/digital IO, you would probably use in, out and digital 00 in practice, but I made them different for clarity)
toolchange.ngc:
O<toolchange> SUB O100 IF [#<_carousel_homed> EQ 0] ; Do we need to home? M66 E0 L0 ; read current stepgen pos into #5399 M68 E1 Q[10 + #5399] ; set the carousel in motion, by more than the number of pockets past the current pos M66 P2 L1 Q20 ; Wait for the home pin O200 IF [#5399 LT 0] (abort, home timeout) O200 ENDIF ; end of timeout check M66 E0 L0 ; read home pin pos into #5399 M68 E1 Q[#5399] ; goto home pin, might need an offset here G4 P5 ; wait for stop #<_carousel_homed> = 1 ; mark homing as done O100 ENDIF ; end of homing (Normal toolchange without homing) M66 E0 L0 ; read current stepgen pos into #5399 #1 = #<_selected+pocket> - #<_current_pocket> ; calculate move distance O300 IF [#1 LT 0] if moving to a lower number #1 = [#1 + 8] ; for an 8-pocket changer O300 ENDIF M68 E1 Q[#1 + #5399] ; move the requisite number of pockets G4 P10 ; Wait (should really wait-on-input on a stepgen-in-position signal) M68 E1 Q[#1 + #5399 - 1] ; move back against the stop G4 P2 ; wait to stall against the stop M6 T<_selected_tool> G43 ; change the tool, set offsets O<toolchange> ENDSUB ; Done
Last edit: 1 year 5 months ago by andypugh. Reason: Forgot to set the homing parameter
The following user(s) said Thank You: tommylight, Adam Maszynotwór
1 year 5 months ago - 1 year 5 months ago #327609 by Adam Maszynotwór
Thank you for presenting other approaches to the subject. It allows me to better understand the general principle of operation of various concepts and HAL structures
I will test your suggestions (it will take me some time) and I will definitely describe it on the forum so that it will be helpful for other and so that they do not bother you with nonsense like me hehe :) )
Last edit: 1 year 5 months ago by Adam Maszynotwór.
Time to create page: 0.167 seconds
