- Configuring LinuxCNC
- Advanced Configuration
- G53 not ignoring tool length offset after a Python M6 remap
- DonatasO
17 May 2025 12:21 - 17 May 2025 12:33 #328623
by DonatasO
G53 not ignoring tool length offset after a Python M6 remap was created by DonatasO
I'm writing an M6 remap in Python and encountered strange and dangerous behavior. After the first M6 call, G53 G0 takes into account the tool length offset, which should not be happening.
I'm unsure if I'm doing something wrong or if this is a bug in LinuxCNC. I hope you can help me clarify and resolve it.
LinuxCNC version: 2.9.4
UI (probably irrelevant): qtdragon_hd
This is a minimal working code to reproduce the issue:
Steps to reproduce the issue:
Attaching debug logs for each command:
T6 M6
Issuing EMC_TASK_SET_MODE -- ( +504,+24, +6, +3,)
NML_INTERP_LIST(0x55561aff7b10)::clear(): discarding 0 items
NML_INTERP_LIST(0x55561aff7b10)::append(nml_msg_ptr{size=24,type=EMC_TASK_PLAN_SYNCH}) : list_size=1, line_number=0
emcTaskPlanSynch() returned 0
NML_INTERP_LIST(0x55561aff7b10)::get(): {size=24, type=EMC_TASK_PLAN_SYNCH}, list_size=0
emcTaskPlanLevel() returned 0
Issuing EMC_TASK_PLAN_SYNCH -- ( +516,+24, +0,)
Issuing EMC_TASK_PLAN_EXECUTE -- ( +509,+280, +7,t6\032m6\n,)
NML_INTERP_LIST(0x55561aff7b10)::append(nml_msg_ptr{size=280,type=EMC_OPERATOR_DISPLAY}) : list_size=1, line_number=0
NML_INTERP_LIST(0x55561aff7b10)::append(nml_msg_ptr{size=24,type=EMC_TOOL_PREPARE}) : list_size=2, line_number=0
NML_INTERP_LIST(0x55561aff7b10)::append(nml_msg_ptr{size=24,type=EMC_TOOL_SET_NUMBER}) : list_size=3, line_number=0
emcTaskPlanExecute(t6 m6
) returned 2
emcTaskPlanLevel() returned 1
emcTaskPlanSetWait() called
NML_INTERP_LIST(0x55561aff7b10)::append(nml_msg_ptr{size=24,type=EMC_TASK_PLAN_SYNCH}) : list_size=4, line_number=0
NML_INTERP_LIST(0x55561aff7b10)::get(): {size=280, type=EMC_OPERATOR_DISPLAY}, list_size=3
Issuing EMC_OPERATOR_DISPLAY -- ( +13,+280, +0, +0,\032in\032prepare\032tool=6.000000\032pocket=6.000000,)
NML_INTERP_LIST(0x55561aff7b10)::get(): {size=24, type=EMC_TOOL_PREPARE}, list_size=2
Issuing EMC_TOOL_PREPARE -- ( +1104,+24, +0, +6,)
NML_INTERP_LIST(0x55561aff7b10)::get(): {size=24, type=EMC_TOOL_SET_NUMBER}, list_size=1
Issuing EMC_TOOL_SET_NUMBER -- ( +1109,+24, +0, +6,)
emcTaskPlanClearWait() called
NML_INTERP_LIST(0x55561aff7b10)::append(nml_msg_ptr{size=280,type=EMC_TASK_PLAN_EXECUTE}) : list_size=1, line_number=0
NML_INTERP_LIST(0x55561aff7b10)::get(): {size=280, type=EMC_TASK_PLAN_EXECUTE}, list_size=0
Issuing EMC_TASK_PLAN_EXECUTE -- ( +509,+280, +0,\255,)
NML_INTERP_LIST(0x55561aff7b10)::append(nml_msg_ptr{size=168,type=EMC_TRAJ_SET_OFFSET}) : list_size=1, line_number=0
emcTaskPlanExecute((null)) returned 0
NML_INTERP_LIST(0x55561aff7b10)::get(): {size=168, type=EMC_TRAJ_SET_OFFSET}, list_size=0
Issuing EMC_TRAJ_SET_OFFSET -- ( +223,+168, +0,0.000000,0.000000,-50.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,)
mdi_execute_hook: MDI command 't6 m6
' done (remaining: 0)
tool_result(id=6, xoffset=0.0, yoffset=0.0, zoffset=-50.0, aoffset=0.0, boffset=0.0, coffset=0.0, uoffset=0.0, voffset=0.0, woffset=0.0, diameter=6.0, frontangle=0.0, backangle=0.0, orientation=0)
G53 G0 Z0
Issuing EMC_TASK_PLAN_EXECUTE -- ( +509,+280, +8,g53\032g0\032z0\n,)
NML_INTERP_LIST(0x55561aff7b10)::append(nml_msg_ptr{size=208,type=EMC_TRAJ_LINEAR_MOVE}) : list_size=1, line_number=15
emcTaskPlanExecute(g53 g0 z0
) returned 0
NML_INTERP_LIST(0x55561aff7b10)::get(): {size=208, type=EMC_TRAJ_LINEAR_MOVE}, list_size=0
Outgoing motion id is 15.
Issuing EMC_TRAJ_LINEAR_MOVE -- ( +220,+208, +0,0.000000,628.000000,-50.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000, +1,100.000000,100.000000,1000.000000, +0, -1,)
Motion id 15 took 0.708401 seconds.
Motion id 0 took 0.000000 seconds.
mdi_execute_hook: MDI command 'g53 g0 z0
G49
Issuing EMC_TASK_PLAN_EXECUTE -- ( +509,+280, +9,g49\n,)
NML_INTERP_LIST(0x55561aff7b10)::append(nml_msg_ptr{size=168,type=EMC_TRAJ_SET_OFFSET}) : list_size=1, line_number=15
emcTaskPlanExecute(g49
) returned 0
Issuing EMC_TRAJ_SET_OFFSET -- ( +223,+168, +0,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,)
mdi_execute_hook: MDI command 'g49
G43
Issuing EMC_TASK_PLAN_EXECUTE -- ( +509,+280, +11,g43\n,)
emcTaskPlanExecute(g43
) returned 0
mdi_execute_hook: MDI command 'g43
G53 G0 Z0
Issuing EMC_TASK_PLAN_EXECUTE -- ( +509,+280, +12,g53\032g0\032z0\n,)
) returned 0
Issuing EMC_TRAJ_LINEAR_MOVE -- ( +220,+208, +0,0.000000,628.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000, +1,100.000000,100.000000,1000.000000, +0, -1,)
Motion id 15 took 0.713359 seconds.
# REMAP=M6 modalgroup=6 prolog=change_prolog python=is_this_a_bug epilog=change_epilog
def is_this_a_bug(self):
if self.task == 0: # ignore the preview interpreter
return INTERP_OK
emccanon.CHANGE_TOOL_NUMBER(self.selected_pocket)
yield INTERP_EXECUTE_FINISH
pose = EmcPose()
pose.z = -50
emccanon.USE_TOOL_LENGTH_OFFSET(pose)
yield INTERP_OKSteps to reproduce the issue:
- Turn on and home the machine
- T6 M6: the tool is loaded and offsets are set correctly.
- G53 G0 Z0: the spindle rapids down to -50mm. This is not expected.
- G49: cancel tool length compensation.
- G43: enable tool length compensation
- G53 G0 Z: the spindle rapids back up to zero. This is expected.
T6 M6
Warning: Spoiler!
) returned 2
G53 G0 Z0
Warning: Spoiler!
) returned 0
G49
Warning: Spoiler!
) returned 0
G43
Warning: Spoiler!
) returned 0
G53 G0 Z0
Warning: Spoiler!
) returned 0
Last edit: 17 May 2025 12:33 by DonatasO.
- Thank you received: 2164
17 May 2025 13:44 - 17 May 2025 13:48 #328628
Replied by Aciera on topic G53 not ignoring tool length offset after a Python M6 remap
Not sure but I think that 'emccanon.USE_TOOL_LENGTH_OFFSET(pose)'
might actually not be a good approach here.
Note that 'G53' will actually use the 'tool_offset' values to calculate the target coordinates:
github.com/LinuxCNC/linuxcnc/blob/1b8867.../interp_find.cc#L197
My guess would be that your change of tool-length is possibly not reflected in 'tool_offset.tran.z'.
Generally I've become very cautious about using 'emccanon' commands to manipulate offset values in remaps. I've had a similar issue setting work offsets this way.
I changed to using 'self.execute(..' instead (although that has its own pitfalls).
See the mentioned issue with work offsets:
forum.linuxcnc.org/20-g-code/48199-chang...-self-execute#264285
if(block->z_flag) {
*pz = block->z_number - s->origin_offset_z - s->axis_offset_z - s->tool_offset.tran.z;
} else {
*pz = s->current_z;
}My guess would be that your change of tool-length is possibly not reflected in 'tool_offset.tran.z'.
Last edit: 17 May 2025 13:48 by Aciera.
- DonatasO
17 May 2025 14:31 #328629
by DonatasO
Replied by DonatasO on topic G53 not ignoring tool length offset after a Python M6 remap
Thanks for the reply.
I can't use self.execute() as using INTERP_EXECUTE_FINISH is unavoidable in my procedure, and no MDI commands can be sent after it. I made it possible to switch between ATC and manual tool change (like drop tool, ask to insert a new one).
At least my understanding about emccanon.USE_TOOL_LENGTH_OFFSET() is that it's supposed to be the equivalent of G43, as it issues the same EMC_TRAJ_SET_OFFSET message. Apparently, it does not fully update the initial state.
Calling USE_TOOL_LENGTH_OFFSET() multiple times before moving does not resolve the problem.
- DonatasO
17 May 2025 14:53 #328632
by DonatasO
Am I missing some call to auto-update it, or does it have to be handled in the remap?
You're right, it's not updated. Setting `self.tool_offset = pose` manually resolves the issue.My guess would be that your change of tool-length is possibly not reflected in 'tool_offset.tran.z'.
17 May 2025 15:10 #328634
note that 'G43' reads the tool-offset values from the tool table:
github.com/LinuxCNC/linuxcnc/blob/6c4303...erp_convert.cc#L6202
and calls emccanon.USE_TOOL_LENGTH_OFFSET() in line 6280:
BUT it also sets 'tool-offsets' in line 6299:
So it seems that you will have to handle this in the remap.
USE_TOOL_LENGTH_OFFSET(tool_offset);BUT it also sets 'tool-offsets' in line 6299:
settings->tool_offset = tool_offset;So it seems that you will have to handle this in the remap.
- DonatasO
17 May 2025 15:17 #328635
by DonatasO
Thanks again!
Looking at the file you linked, I see ways to simplify some parts in my remap.
This is resolved now. Only the tool length sensor's side will remain scarred
Time to create page: 0.103 seconds
