reference during rotorhoming
30 May 2025 08:09 #329395 by bassti
reference during rotorhoming was created by bassti
Hello,
i have a b - axis and i want to home the axis at the same time as the rotorhoming seqence is running (bldc component)
I run a etel ddm with a 8i20 and a siko encoder with index
Any ideas?
05 Jun 2025 05:30 #329731 by andypugh
Replied by andypugh on topic reference during rotorhoming
Can you elaborate?
What triggers the motor to home?
06 Jun 2025 08:19 #329811 by bassti
Replied by bassti on topic reference during rotorhoming
At the moment, rotorhoming starts when i power on the machine.
The problem is that i want to home the z-axis first.
07 Jun 2025 19:56 #329916 by rodw
Replied by rodw on topic reference during rotorhoming
HOME_SEQUENCE in ini
08 Jun 2025 07:50 #329944 by bassti
Yes, I know how to set the homing order, the question is whether I can stop during the homing sequence, i.e. after z has been homed and then the rotorhoming of the b axis can be fixed and then the remaining axes can be referenced
10 Jun 2025 08:28 #330077 by andypugh
I guess that this means that you need to re-wire the bldc.0.init HAL pin to something other than machine.is-on ?
Possibly to joint.2.homed
Time to create page: 0.187 seconds
