MESA 7i93 PWM question - motor rotation direction switch
08 Jun 2025 14:51 #329966 by pingtomi
Dear All,
I try to set up 7i93 PWM control for my ATC motor and I struggle with its rotation direction change, meaning:
- if pwmgen.0.value = positive number, pwm signal is on PIN6 as expected, motor rotates clockwise.
- if pwmgen.0.value = negative number, there is no PWM signal on PIN8, motor does not rotate at all.
I use PWM controlled mosfet bridge which expects CW and CCW input PWM signals on TTL level.
Regardless of pwmgen.output-type it does not work, but based on hostmot2 manual in my understanding it should work with output-type 2.
7i93's firmware is standard.
What do I wrong, or how can I change the rotation direction with PWM if my motor drive expects CW and CCW PWM signals?
thank you for your help.
Regards,
Tamas
08 Jun 2025 18:01 #329980 by PCW
What does:
mesaflash --device ethernet --addr [card_ip_address] --readhmid
report?
09 Jun 2025 03:43 - 09 Jun 2025 03:43 #330001 by pingtomi
Configuration Name: HOSTMOT2
  BoardName : MESA7I93
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 2
  Width of one I/O port: 24
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 2 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: QCount
  There are 4 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: PWM
  There are 4 of PWM in configuration
  Version: 0
  Registers: 5
  BaseAddress: 4100
  ClockFrequency: 200.000 MHz
  Module: StepGen
  There are 4 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin#                  I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
 1                      0   IOPort       QCount           1        Quad-B          (In)
 3                      1   IOPort       QCount           1        Quad-A          (In)
 5                      2   IOPort       QCount           0        Quad-B          (In)
 7                      3   IOPort       QCount           0        Quad-A          (In)
 9                      4   IOPort       QCount           1        Quad-IDX        (In)
11                      5   IOPort       QCount           0        Quad-IDX        (In)
13                      6   IOPort       PWM              1        PWM             (Out)
15                      7   IOPort       PWM              0        PWM             (Out)
17                      8   IOPort       PWM              1        Dir             (Out)
19                      9   IOPort       PWM              0        Dir             (Out)
21                     10   IOPort       PWM              1        /Enable         (Out)
23                     11   IOPort       PWM              0        /Enable         (Out)
25                     12   IOPort       QCount           3        Quad-B          (In)
27                     13   IOPort       QCount           3        Quad-A          (In)
29                     14   IOPort       QCount           2        Quad-B          (In)
31                     15   IOPort       QCount           2        Quad-A          (In)
33                     16   IOPort       QCount           3        Quad-IDX        (In)
35                     17   IOPort       QCount           2        Quad-IDX        (In)
37                     18   IOPort       PWM              3        PWM             (Out)
39                     19   IOPort       PWM              2        PWM             (Out)
41                     20   IOPort       PWM              3        Dir             (Out)
43                     21   IOPort       PWM              2        Dir             (Out)
45                     22   IOPort       PWM              3        /Enable         (Out)
47                     23   IOPort       PWM              2        /Enable         (Out)
IO Connections for P1
 1                     24   IOPort       StepGen          0        Step/Table1     (Out)
 3                     25   IOPort       StepGen          0        Dir/Table2      (Out)
 5                     26   IOPort       StepGen          0        Table3          (Out)
 7                     27   IOPort       StepGen          0        Table4          (Out)
 9                     28   IOPort       StepGen          0        Table5          (Out)
11                     29   IOPort       StepGen          0        Table6          (Out)
13                     30   IOPort       StepGen          1        Step/Table1     (Out)
15                     31   IOPort       StepGen          1        Dir/Table2      (Out)
17                     32   IOPort       StepGen          1        Table3          (Out)
19                     33   IOPort       StepGen          1        Table4          (Out)
21                     34   IOPort       StepGen          1        Table5          (Out)
23                     35   IOPort       StepGen          1        Table6          (Out)
25                     36   IOPort       StepGen          2        Step/Table1     (Out)
27                     37   IOPort       StepGen          2        Dir/Table2      (Out)
29                     38   IOPort       StepGen          2        Table3          (Out)
31                     39   IOPort       StepGen          2        Table4          (Out)
33                     40   IOPort       StepGen          2        Table5          (Out)
35                     41   IOPort       StepGen          2        Table6          (Out)
37                     42   IOPort       StepGen          3        Step/Table1     (Out)
39                     43   IOPort       StepGen          3        Dir/Table2      (Out)
41                     44   IOPort       StepGen          3        Table3          (Out)
43                     45   IOPort       StepGen          3        Table4          (Out)
45                     46   IOPort       StepGen          3        Table5          (Out)
47                     47   IOPort       StepGen          3        Table6          (Out)
Last edit: 09 Jun 2025 03:43 by pingtomi.
09 Jun 2025 08:29 #330017 by PCW
Are you sure you have the pinout correct?
PWM 0 uses 50 pin connector pins 15,19,23
09 Jun 2025 08:46 #330019 by pingtomi
yes, I meant pin numbers as they are shown in the I/O column, but you are right I had a mistake as I tried to configure pwm1, but I experienced the same behavior with pwm0 on i/o pins 7 and 9.
if I use multimeter I see between 2,5..4V signal on pin6 (depends on the value, of course) but nothing on pin8. (corresponding 50pin numbers are 13,17)
/enable signals work properly.
thx
09 Jun 2025 11:32 - 09 Jun 2025 11:35 #330029 by PCW
Does DIR change in output type 0?
(maybe there's a hardware issue)
Last edit: 09 Jun 2025 11:35 by PCW.
13 Jun 2025 12:30 #330257 by pingtomi
not with type 0, I couldn't set it but with type 1 works (I mean, logic level of the corresponding pin changes properly)
so I think there is no hardware issue.
13 Jun 2025 14:43 - 13 Jun 2025 15:16 #330259 by PCW
Sorry I meant mode 1 (there is no mode 0)
This is pretty odd. I can't duplicate this here. I tested by putting a couple LEDs on the
PWM/DIR lines and in output mode 2 the PWM output changes from the PWM pin to
the DIR pin when the PWM value is negative. In addition, the LED brightness was proportional
to the absolute PWM value as expected.
Its especially odd since the PWM module is unchanged since it s original creation (version 0)
and PWM output mode 2 is used on some of our interface cards (7I48,7I49)
What LinuxCNC version?
Last edit: 13 Jun 2025 15:16 by PCW.
13 Jun 2025 15:27 #330260 by pingtomi
2.9.4
OK, thanks for your confirmation that this should work. I have another 7i93 in production, I'll check with that and come back with the results.
