Error compiling modbus configuration file
- SebastianM
- Thank you received: 3
21 Jun 2025 18:44 - 21 Jun 2025 19:09 #330665
by SebastianM
Error compiling modbus configuration file was created by SebastianM
Hello!
I just tried to compile a modbus file according to this documentation:
linuxcnc.org/docs/2.9/html/drivers/mesa_...#_configuration_file
I attached the file that I created, and imho it looks fine, but the compiler just throws a bunch of errors...
What am I doing wrong
Edit: compiling one of the modbus sample files works fine.. no idea why my file doesnt work... I copied it directly from this post from PCW (as its the same VFD)
forum.linuxcnc.org/27-driver-boards/5533...us-so?start=0#321582
Last edit: 21 Jun 2025 19:09 by SebastianM.
- SebastianM
21 Jun 2025 19:55 #330668
by SebastianM
Replied by SebastianM on topic Error compiling modbus configuration file
ok, nevermind.. I rewrote the file from scratch and now its working.. not idea what happened before.
22 Jun 2025 13:46 #330717
Replied by andypugh on topic Error compiling modbus configuration file
My guess would be that you lost the { at the end ofor possibly the one that terminates that set.
If you still have the good and bad files, then could you attach them? I don't think that I can make the compiler more helpful in it's error messages, but possibly the preprocessor could be.
static const hm2_modbus_chan_descriptor_t channels[] = {If you still have the good and bad files, then could you attach them? I don't think that I can make the compiler more helpful in it's error messages, but possibly the preprocessor could be.
Time to create page: 0.071 seconds
