- Configuring LinuxCNC
- Advanced Configuration
- Robot reads the same position every time it is turned on.
- hellvetica
26 Jun 2025 07:53 #330891
by hellvetica
Robot reads the same position every time it is turned on. was created by hellvetica
Hi, I have a delta robot built on ethercat and running linuxcnc.
We recently got drives with absolute encoders so i had to make a specific homing procedure that just triggers the internal homing on the drives.
The drives then reset their encoder positions internally to 0 or home offset if it's set in HAL with lcec.
Then, when using the robot i could move it somewhere, turn off linux cnc and then start it again and linuxcnc always shows the same position when starting [ 0. , 0. , -496.22474747]. When i disable the home offset this number still stays the same. I move the robot to [0,0,-700], restart and it still shows the same position, and then moves "ignoring" the soft limits. The encoders themselves retain their position information properly, it's just linuxcnc that reads it wrong (or doesn't read it for some reason) What am i missing here?
Here are the files for my config.
- hellvetica
26 Jun 2025 08:18 #330892
by hellvetica
Replied by hellvetica on topic Robot reads the same position every time it is turned on.
I just noticed that halui.axis.x.pos-relative read the value correctly and it retains it after restart. The axis.x.pos-cmd always starts at -496.2247. When i move the robot the halui.axis.x.pos-relative reports the correct absolute position but the robot moves as if it has been started at -496.2247. Any ideas?
- meister
- Thank you received: 502
26 Jun 2025 08:43 #330894
by meister
Replied by meister on topic Robot reads the same position every time it is turned on.
I would try to remove the PARAMETER_FILE (sim_mm.var) and then start the program
- hellvetica
26 Jun 2025 09:13 #330895
by hellvetica
Thanks for the reply.
I removed it but it had no effect.
- Thank you received: 2177
26 Jun 2025 10:07 #330897
Replied by Aciera on topic Robot reads the same position every time it is turned on.
Post your custom homing procedure please.
- hellvetica
30 Jun 2025 08:25 #331035
by hellvetica
The .txt file is actually a .sh file but I can't upload it here
- hellvetica
01 Jul 2025 06:54 #331062
by hellvetica
Sorry, i realised i didn't upload the correct .hal file
Time to create page: 0.107 seconds
