LinuxCNC randomly crashes reportedly due to Python bug
1 year 2 months ago #332793 by matasbuk
Hello, I am running the master branch of LinuxCNC with QTLathe GUI. I have a Python component that reads the feed rate from linuxcnc.stat and further use that value in my C component. The machine seems to randomly hard crash and exit LinuxCNC fully. What could be the problem ar what could I change to solve this? Thank you in advance! I am attaching the Python and C components, .ini and .hal files and the error log.
1 year 2 months ago #332796 by unknown
Unexpected realtime delay on task 0 with period 1000000 This Message will only display once per session. Run the Latency Test and resolve before continuing. Starting DISPLAY program: qtvcp hm2/hm2_7i95.0: Smart Serial port 0: DoIt not cleared from previous servo thread. Servo thread rat.sserial.0.fault-count pin will indicate if this is happening frequently.
The error log has identified an issue (noted above), you will need to address this.
1 year 2 months ago #332819 by matasbuk
Solving the realtime delay should solve this? Didn’t consider this as I thought Python did not ran in realtime
1 year 2 months ago #332820 by tommylight
1. whatever you are doing to log all the 0's and 50's , don't, just had to scroll through over 70 pages of it, it is not fun and wastes a lot of very precious time
2. none of the two mentioned errors will not stop the LinuxCNC from running
3. Python error, as noted at the end of a very long error log, having to do with jog buttons as it seems
Try using Axis GUI, make the machine work properly by fixing latency issues and the "dolt not cleared" as this will disable the Mesa card completely.
Then try other GUI's.
1 year 2 months ago #332865 by rodw
Why are you using Python when the feed rate is available in real time in motion? There are other options but try this pinmotion.feed-upm OUT FLOATCurrent feed rate in G-code program units per minute for motion.motion-type feed(2) and arc(3). Value is the G-code program F value multiplied by the current feed override value and the motion.adaptive-feed setting (if M52 active). Value is zero if motion.feed-hold or motion.feed-inhibit are asserted. If units (G20 or G21) are not specified in the G-code file then units will be the last units used. linuxcnc.org/docs/stable/html/man/man9/motion.9.html
1 year 2 months ago - 1 year 2 months ago #333045 by MennilTossFlykune
I've also been getting this in QtDragon_hd.
Fatal Python error: none_dealloc: deallocating None: bug likely caused by a refcount error in a C extension Python runtime state: initialized Thread 0x00007f9835f3c6c0 (most recent call first): <no Python frame> Thread 0x00007f9863bff6c0 (most recent call first): <no Python frame> Current thread 0x00007f98aa3ed040 (most recent call first): File "/home/user/Documents/linuxcnc/lib/python/qtvcp/widgets/state_led.py", line 140 in change_state File "/home/user/Documents/linuxcnc/lib/python/qtvcp/widgets/state_led.py", line 135 in _flip_state File "/home/user/Documents/linuxcnc/lib/python/qtvcp/widgets/state_led.py", line 237 in _set_halpin_text File "/home/user/Documents/linuxcnc/lib/python/qtvcp/widgets/state_led.py", line 130 in <lambda> File "/home/user/Documents/linuxcnc/lib/python/common/hal_glib.py", line 930 in update File "/home/user/Documents/linuxcnc/bin/qtvcp", line 463 in __init__ File "/home/user/Documents/linuxcnc/bin/qtvcp", line 607 in <module>
It was caused by this commit:
github.com/LinuxCNC/linuxcnc/commit/656a...de1ab167c3e89f700a7e
In halmodule.cc, if all occurrences of
return Py_None;
are changed back to
Py_RETURN_NONE;
the error goes away.
Last edit: 1 year 2 months ago by MennilTossFlykune.
The following user(s) said Thank You: matasbuk
Time to create page: 0.404 seconds
