displayed axis
24 Aug 2025 06:28 #333835 by jorgearma0205
displayed axis was created by jorgearma0205
I am updating a grinding machine which only has the y and z axes controlled by a motor, the x axis is hydraulically driven with limit sensors, I already have the machine working with an old 5i23, I configured the x axis to not have errors in pncconf by configuring a linear encoder mounted on the x axis with the intention of being able to visualize them but when running a program it shows me a tracking error obviously given that there is no x movement command and the encoder starts to count, is it possible to disable the hili of the x axis only keeping the encoder count to be able to visualize the x axis on the screen?
27 Aug 2025 11:41 #333986 by andypugh
Replied by andypugh on topic displayed axis
I am not entirely clear what problem you are seeing, but you should just be able to set the F-ERROR limits for the X axis very high, and then no errors will be raised.
If the problem isn't following-error trips, then I think we need more info.
Time to create page: 0.334 seconds
