Carousel with counts move x amount of pockets
- GDTH
06 Sep 2025 19:19 #334559
by GDTH
Carousel with counts move x amount of pockets was created by GDTH
Hi all,Before I head to bed, I wanted to ask if anyone can quickly help me with my current frustration: getting this machine’s carousel working.I’ve got homing working, but there’s something odd—if the carousel is already homed and I try to home it again, nothing happens. I’ve managed to get M13 working, but I still need to sort out M11 and M12. I’ll attach my HAL and INI files here.I’m wondering if there are better ways to handle this, or if there are any good examples I could look at. My machine doesn’t have sensors for the pockets (which I would have preferred), so I’m working around that.Right now my biggest struggle is that I’m getting “unary” errors from my subroutine. When I try to trace the problem, the error messages aren’t very clear about what’s actually wrong. Is there a way to debug subroutines more effectively? At the moment the basic error messages don’t give me enough detail to figure it out.Any tips would be greatly appreciated
- Thank you received: 4648
09 Sep 2025 12:48 #334691
Replied by andypugh on topic Carousel with counts move x amount of pockets
Are you sure that EVAL[.....] is valid? Is that documented somewhere?
I don't recognise it as one of the documented unary functions, but can see examples of its use on the forums. I know that py and pyrun exist (I can see them in the source code, they may not be documented) but eval has me stumped.
- GDTH
16 Sep 2025 19:17 #335081
by GDTH
Replied by GDTH on topic Carousel with counts move x amount of pockets
I’ve made some good progress with the carousel. It turned out that some parameters need to be set to 0 when using counts mode, and with that change I’ve got it almost working perfectly. Homing and jogging both run flawlessly through the shell M-codes.The only issue I’m stuck on now is when I tryto rotate to a specific pocket. At that point it just hangs in state 8, because thevariable stays at 0 and won’t let the sequence continue.What’s odd is that when jogging it also goes through state 8, but in that case it’s able to pass through just fine. So it feels like I’m missing something.Any tips or ideas on what might be causing this?
M120align-pinPlease Log in or Create an account to join the conversation.
17 Sep 2025 18:04 #335134
What does M120 do?
- GDTH
17 Sep 2025 18:15 #335135
by GDTH
Basically what the original m10 from probe basic does. It tells the carousel comp the pocket number
17 Sep 2025 18:21 #335137
What happens if you just wire selected-pocket directly in HAL?
- GDTH
18 Sep 2025 06:32 #335148
by GDTH
mmh, i dont understand. how would you do this? I thought you had to do it through a subroutine or m code.
Btw, this is how the m120 looks like.
24 Sep 2025 14:31 #335368
At its simplest
Then whenever the carousel.0.enable goes true, it will drive to that pocket.
All the subroutines etc are about the other things that have to happen before carousel motion, such as tool unload, spindle lift etc.
net requested-pocket iocontrol.0.tool-prep-pocket => carousel.0.pocket-numberThen whenever the carousel.0.enable goes true, it will drive to that pocket.
- GDTH
27 Sep 2025 13:52 #335488
by GDTH
okay, i will sure to be using in that in the end. however when i am using M120 or just put the pocket number manualy it just gets stuck in state 8 where it is waiting for align_pin to be something else then 0. As nothing moves , this will never happen. also i constantly getting the error "the toolchanger has hailed its alignment check". I have used the carousel comp many times. howeve this is the first time with only a stepgen. with that in mind and that i barely find anyone use it the same i am question if this actualy works with stepgen (Counts).
- GDTH
27 Sep 2025 18:34 #335499
by GDTH
i have copied the carousel component and removed the align_pin if statement from state 8. I think this is ment for dc motors. So far it seems to work fine.
Time to create page: 0.211 seconds
