Carousel with counts move x amount of pockets
- Thank you received: 4648
28 Sep 2025 17:46 #335514
Replied by andypugh on topic Carousel with counts move x amount of pockets
"align-pin" isn't a physical pin (or, rather, it _can_ be a physical pin, but which one it maps to is dependent on mode)
In the step counts case:
github.com/LinuxCNC/linuxcnc/blob/master...s/carousel.comp#L292
And I am somewhat concerned that I have made an error there, as I don't think that the % operator will return a negative value.
I can see what my code was trying to do, but I suspect it doesn't do it.
Do you know what your counts (and scale) were at the point that the system got stuck?
- GDTH
29 Sep 2025 15:56 #335554
by GDTH
Replied by GDTH on topic Carousel with counts move x amount of pockets
setp carousel1.0.scale 2000
setp carousel1.0.width 200
setp carousel1.0.home-offset 800
setp carousel1.0.debounce 3
02 Oct 2025 12:16 - 02 Oct 2025 12:17 #335711
Sorry, but to test I would need to know the actual encoder/step counts that were being fed into the component at the point of failure.
But, I am sure that the code linked above is very wrong, and is likely to be the problem.
Can you:
1) Make sure that you have the linuxcnc-uspace-dev package installed.
2) Download the attached carousel.comp file
3) From the folder where you saved the file
And see if the problem is fixed?
Can you:
sudo halcompile --install carousel.compAnd see if the problem is fixed?
Last edit: 02 Oct 2025 12:17 by andypugh.
Time to create page: 0.136 seconds
