Carousel with counts move x amount of pockets
1 year 4 weeks ago - 1 year 4 weeks ago #335711 by andypugh
Sorry, but to test I would need to know the actual encoder/step counts that were being fed into the component at the point of failure.
But, I am sure that the code linked above is very wrong, and is likely to be the problem.
Can you:
1) Make sure that you have the linuxcnc-uspace-dev package installed.
2) Download the attached carousel.comp file
3) From the folder where you saved the file
sudo halcompile --install carousel.comp
And see if the problem is fixed?
Last edit: 1 year 4 weeks ago by andypugh.
Time to create page: 0.094 seconds
