MB2hal interface to a H100 inverter
  • davmer42
  • Topic Author
  • New Member
  • New Member
1 year 1 month ago #335639 by davmer42
MB2hal interface to a H100 inverter was created by davmer42
Hi guys and gals. I have been spending hours and hours trying to get a H-100 inverter to talk to linux cnc. The documentation is just foggy enough that I am at a loss. I can connect the spindle(0) bits to the MB2hal transaction names but apparently I'm not using the correct addresses and int's / float's. And the limited instructions don't give me enough crayons. I have defined a pin called mb2hal.readhldreg.start but do not know how to tie it to the correct register.
All I see is mb2hal.m.n.float or int or bit. I do not know what m or n is.
This is rather embarrassing as I spent a career in plc's and programming.
If someone could give me some examples, it would be greatly appreciated.
Thank you, David
1 year 1 month ago - 1 year 1 month ago #335652 by Hakan
Replied by Hakan on topic MB2hal interface to a H100 inverter
No expert by any means, but I got it to work so here are some snippets from that
in custom_sinusM.hal
# Load mb2hal for modbus operation of the sinusM vfd loadusr -Wn sinusM mb2hal config=sinusM_spindle.ini ... # Set max limit rpm for spindle # net spindle-max-freq       sinusM.05.read-max-freq.float spindlemax.max         # Max frequency(rps) for motor net  spindle-speed-scale   spindle.0.speed-out-rps-abs   sinusM.01.set-freq     # Just the principle net spindle-vel-positive    mux4.0.sel0           abs.spindle-speed.sign net spindle-enable          mux4.0.sel1 net spindle-cmd-out         mux4.0.out            sinusM.04.run-command  # Stop/fwd/rev
In sinusM_spindle.ini
... [TRANSACTION_01] MB_TX_CODE=fnct_06_write_single_register FIRST_ELEMENT=4 NELEMENTS=1 PIN_NAMES=set-freq MAX_UPDATE_RATE=0.0 [TRANSACTION_04] MB_TX_CODE=fnct_06_write_single_register FIRST_ELEMENT=5 NELEMENTS=1 PIN_NAMES=run-command MAX_UPDATE_RATE=0.0 [TRANSACTION_05] MB_TX_CODE=fnct_03_read_holding_registers FIRST_ELEMENT=41492 NELEMENTS=1 PIN_NAMES=read-max-freq MAX_UPDATE_RATE=0.0
The above communication works with the vfd. But hal code is probably mixing Hz and rpms so it won't necessarily work for that reason.
Last edit: 1 year 1 month ago by Hakan.
Time to create page: 0.047 seconds
